Iwant to Buy a GPU Card Between £100 to £120 With VGA Port & DirectX 11.0 Pls Help
  • Thread starter Thread starter bally303
  • Start date Start date
B
bally303
So i want to get a new Graphics Card So i can play Crysis 3 I have found a GPU that i like but dont know if it will work in my HP rig the GPU i want to buy is
Asus GeForce GTX 650 Ti Nvidia Graphics Card (1GB GDDR5, HDMI, VGA, 2x Dual-link DVI-D, PCI Express 3.0, OpenGL 4.3, GPU Tweak, DIGI+ VRM with Super Alloy Power Technology)my PC is HP Pavillion p6109uk
MY Motherboard is IPIEL-LA3 (Eureka3)
here is my PC specs Site:-
HP Pavilion p6100 Desktop PC series -  HP Pavilion p6109uk Desktop PC Product Specifications - c01792607 - HP Business Support Center
& here is my motherboard specs Site:-
Motherboard Specifications, IPIEL-LA3 (Eureka3) | HP® Support
so the GPU i want to buy says its PCI Express 3.0 & i only have PCI-E x16 i think its 1.0 not shore as i cant find it out anyware on the web, if you could pls let me know..
so can you help & tell me if this will work with my pc
PS
i have done a few mods with HP Pavillion p6109uk PC by placing it in a new mid-tower case & a new PSU has also been added corsair 650w PSU & a 2 month old GPU GEforce GT240 Has also Been added, nice card but its only DirectX 10.1 Compatable, Bit of a buzz kill if you ask me... as crysis 3 needs DirectX 11 to play..
Re: Iwant to Buy a GPU Card Between £100 to £120 With VGA Port & DirectX 11.0 Pls Hel
That card will be just fine in your mobo, only possible issue is physically fitting in your case as you didn't mention what you switched too.
Your mobo is pci-e 2.0, which is perfectly compatible with pci-e 3.0.
The 240 came out before dx11 so what do you expect? It actually is a fairly old card.. Probably 3 yrs or more as it was "replaced" by the gt540.
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
Thanks for Your reply, & to anwser your question my new case is Corsair 600t white, I really wasnt complaining about 240 card only about the newly released games, By the way, As i only paid £20 for it as a temp replacement for a faulty Geforce G210 card, i mean a 3 year old card & it plays almost all games except for all the Crysis games, i mean all the crysis games work but theres a lot of lag on it which makes it unplayable in my opinion I knew at the time of purchase it didnt have direct x 11, But now with most games demanding directx11 I thought its about time i invest in a better card as the 240 was only a temp card.
Also another Question? would the Radeon series cards work in my PC, Because i like this card it looks good & has great reviews its called
{ Radeon HD 7850 1 GB..} or am i bound to only Nvidia GPUs, Pls reply
You will undoubtedly have to get a more powerful PSU. 300 watts isn't much. Keep in mind that the Crysis games are very resource intensive.
    Windows 8.1 Industry Pro x64
    HP Pavillion Elite HPE-250f
    8 gb
    ATI Radeon HD 5770 1 gb ram
    Alienware 25 AW2521HF
    1920x1080 &1680x1050
    1 TB x2
    Dell Poweredge T140
    8GB 2666MT/s DDR4 ECC UDIMM
    1 TB & 360 GB x2
As I metioned in the first post i have a 650w corsair PSU
Ah yha sorry I forgot you went with the 600T.
AMD cards are good, but they are notorious or having driver issues. The 7850 is a better card, but by 10fps-ish. The question to you becomes is the increase in cost worth the gains.
Both cards will do you just fine, its up to you if the £40-60 is worth it.
