All,
I am completely lost here. I have read soooo much great information on the mechanics of changing out the card, but can't use any of it "yet" because I'm still at the basic level of trying to figure out what my computer can take. I'm also having a brain freeze on some of the terminology.
What makes it even worse is that I switched out the card a few years ago from a GeForce 8 series to a GeForce 9300, so I know I must have had all this information then, but for the life of me, I can't remember how I found it, what it means, or where I put it - please HELP!! I feel like such a techno-dope
My computer info is:
Model: HP m8530f
Processor: AMD Phenom(tm) 9550 Quad-Core Processor 2.20 GHz
Memory (RAM): 7.00 GB
System Type: 64-bit
O/S: Vista Home Premium
I believe I need to know the following info before I go forward. Please let me know what else I need to know as well.
Questions:
How do I figure out what the power source is?
How do I determine what kind of interface the computer is using? SLI, DVI - I assume those are interface types??
How do I determine what card will fit into my computer? (one of the articles specifically warned to check this first!).
No idea how to determine what the case is
How do I know if I need to upgrade the fan (the GeForce 9300 tends to run "HOT" - not good) and if I do . . . all the above questions will apply to this.
**sigh** I'm sooo lost.
Thank you all in advance for your help AND patience.
Meltie
Model: HP m8530f
System Type: 64-bit
Questions:
Meltie
- HP
- NVidia
