ATI Radeon HD 4850
Asus P5Q Pro
Antec PSU 850
OCZ Reaper 2g x2
Vista Ultimate 64
1st time it happened was while playing a game
2nd time was playing starcraft 2
3-5th time was watching video or was idle...
Problem:
-Color Strips pop out on screen
-Monitor has no signal
-GPU fan is running loudly (like its running 100% speed) - D1601 light is on (overhating) but gpu temp was at 40-45 (idle)(65% fan speed)
What i've tried so far:
-Switch PCI slots
-Switch Ram slots
-Replaced DVI cables
-Replaced Monitors
-Replaced 6pin connectors
-Replaced HDD sata wires
-cmos bat reset
-cmos pin reset
-cleaned the fan
-reapplied thermal paste couple of times
-while able to login to windows:
* reinstalled ati drivers - cleaned registry and drivers
* event viewer seems to have nothing on it
* been to many forums but cant find a fix
more info:
***i have my pc working for 2-3years now had overheating issues 2 years ago and got it fixed***
***was on vacation and my pc was not in use for 4 months***
***started using it again since feb(problem occured 2weeks ago)***
***While Switching Rams did get me to BIOS msg but screen went blank in 1sec...screen has color strips blinking again***
***not reseating the GPU properly seems to work (not seating it all the way... kinda loosed) but same problem happens in couple mins or so***
it happened before and i got it working again (twice) and it worked for 1-2days and problem occured again
nothing seems to work this time...
***dont have another pc to try the GPU if it works***
Please Help... Thanks...
Asus P5Q Pro
Antec PSU 850
OCZ Reaper 2g x2
Vista Ultimate 64
Problem:
-Switch PCI slots
-Switch Ram slots
-Replaced Monitors
-cmos bat reset
-cmos pin reset
-cleaned the fan
more info:
- Intel Core 2 Quad Q6600 Kentsfield 2.4GHz
- ASUS P5Q PRO
- OCZ Reaper HPC 2 x 2GB DDR2 1066
- ATI RADEON HD4850
- Auzen X-Fi Prelude 7.1
- 1280 x 1024
- Seagate Barracuda 7200.10 ST3400620AS 400GB 7200 RPM SATA 3.0Gb/s Hard Drive
- PSU
- Antec TPQ-850 850W
- Case
- Antec Nine Hundred
