ranger72
Hi There everyone!
This is a new build. Please check the spec's for this machine.
My default OS is Win 7 Ultimate 64 Bit. When I am using this OS all Is good with my monitors. My left screen is my primary screen and has the start button and all my short-cut icons on it which is the way I would like it to be in all three Os'. I can open many panes and move them back and forth to any screen I want.
When I restart the system to enter into Win Vista Home premium My Right screen is the primary screen and I cannot move any panes into the left screen and i cannot move the cursor into the left screen.
When I open the device manager in this OS there are no problems showing in either the display adapters or the monitor criteria.
I have tried correcting the problem in both the windows control panel in displays and also in the Nvidia control panel and I can't seem to solve this problem.
What do i need to do to get my left monitor to be my primary screen and to move window panes from left to right and vice versa.
Not sure but I think this is a driver issue.
Thank you for your help.
ranger72
ranger72
- Home Build
- Intel Core i7 950 Bloomfield Quadcore 3.06 Ghz LGA 1366 Sock
- ASUS Sabertooth X58
- 12 Gigs Corsair Dominator-GT DDR3 PC3-15000 (1866Ghz) vista sees 4gs
- Nvidia powered EVGA GTX 460 1024 MBs of DDR5 memory
- Creative SoundBlaster X-FI Titanium Fatality Pro Series
- Dual AOC 23" LCD (LED Backlit) 5MS recovery 30,000:1 contrast Flatsdreen Monitors
- 1920 X 1080 Native Resolution
- Hitachi 1TeraByte S-ATA running WIN 7 Ultimate 64 Bit OS Hitachi 320 GIG S-ATA running WIN Vista Home Premium 32 Bit OS Hitachi 320 GIG S-ATA running WIN XP Pro 32 Bit OS
- PSU
- Corsair Modular AX 850 Watt Pro Series Gold Certified PSU
- Case
- CoolerMaster HAF X RC-942-KKN1 Full Tower
- Cooling
- CoolerMaster V-8 180W CPU/Heatsink Cooler
- Logitech MX3200 Wireless Keyboard/Mouse Combo
- Fairpoint ISP 15Mbps Download/ 2 Mbps uoload speed
- Other Info
- Case Fans 1 320MM Megaflow Front Case Fan 1 200MM Megaflow Top Case Fan 1 200MM Megaflow Side Case Fan 1 200MM Megaflow Rear Case Fan 1 Double fan cooler unit for Corsair ram 1 PSU exhaust fan All fans are red Led fans and there is additional mod case lighting This Box is a Beast :>)
