Dedicated system memory for graphics card as zero?
[RESOLVED] Dedicated system memory for graphics card as zero?
I have found that any Vista or W7 machine that has a "0" value indicated in the Dedicated System Memory fails to run my apps. So there is no easy way to change this value? i dont expect a user to change a bios setting.
Dedicated system memory is what the CARD gives to the PC. So if you have an app taking most of your ram, the card will give it its own DEDICATED system memory. But your pc has dedicated GRAPHICS that is for aero and gaming. So if you have 1GB= 1024 MB and 64MB DEDICATED SYSTEM MEMORY, your COMPUTER can use 1088MB TOTAL for APPS.
hope this helps.
    Custom Gaming Rig 780G
    AMG Athlon II X2 255 3.8/2MB/2500MHz 45nm AM3
    Gigabyte GA-MA78LMT-S2 AM3, Core Boost, Ultra Durable 3
    2X 4GB Kingston DDR3 1066MHz @ 1666MHz Dual Channel
    HIS HD Radeon 7770 GHz Edition iCooler Core: 1000MHz
    Realtek HD Audio
    Dell E2311H DVI/VGA 5ms response, Full HD
    1920x1080 @ 60Hz
    320GB Seagate Barracuda 7200.02 SATA II
    Cooler Master Extreme Power Plus 700w
    Lian-Li PC-6010 With Side Window
    Aywun A4 80mm fan
    Logitech K120 Wired Mouse
    Logitech K120 Wired Keyboard
    802.11B/G/N 17Mb/s
    AMD Catalyst 12.6 Thomson A/B/G/N Router LiteON CD/DVD Player GAME PERFORMANCE: Battlefield 3: 41 FPS High 1x AA @ 1280x720 Mass Effect 2 and 3: 60 FPS Highest 4x AA @ 1920x1080 Counter Strike Source (and other Valve games): 300 FPS (max FPS in game) Highest settings 8x AA 16x AF @ 1920x1080!!!
thx, i sorted it out
My app has a undo/redo function and the app was writing a image to the memory every time the mouse-up event was triggered so when the undo/redo was executed we had the last image in the memory to show.
I edited the code to only save the changes and not the whole image.
