Ok, I think I've exhausted every forum looking for a solution to my problem. So I'm posting here in the hope someone can help.
The problem:
I added a second monitor to the GeForce 7100 GS using a DVI-VGA adapter and for the life of me cannot get it to display anything, the monitor is just in sleep mode.
I've got the latest driver, Windows is up to date, checked the cables, tried another adapter, tried everything but, still nothing.
The second monitor shows up in the device manager and in the Nvidia control panel. It's enabled and set to extend desktops. It seems the system knows it's there because I can move the mouse over, but cannot see anything. The power light on the second monitor just flashes.
I've swapped monitors over, to make sure there's not a problem with the display and it's fine. When I do that, the main monitor is then plugged in to the DVI adapter and then that one goes to sleep. Just seems whichever monitor is plugged in to the DVI-VGA adapter just doesn't want to work.
System Details are:
Windows Vista Home Edition 32bit Service Pack 2
Nvidia Geforce 7100GS using driver 197.45
Primary Monitor: Philips 190WV
Secondary Monitor: Samsung Syncmaster 943SN
I have another system set up virtually the same, but using a Geforce 7300 GS on Windows XP and I have no problems at all with that, just plugged everything in and it worked straight away. So, is this a Vista or a Nvidia problem...I don't know.
If anyone can help with this I'd be really grateful! The second monitor setup on this system is my girlfriends and it was a birthday present, but she's not been able to use it yet and it was her birthday 2 weeks ago....
Please if anyone knows a way round.
Thanks for your time!
The problem:
System Details are:
