Monitor shut down when laptop door closes
I have a Dell Vostro 1500 laptop running Vista Home Basic. Recently acquired an Acer 24" monitor, and daily swap the laptop between 17" monitor and the new one.
Connecting to the new 24" monitor works great: plug everything in, start it up (from hibernate) and monitor displays.
Connecting to the 17" monitor, same process, unless I leave the laptop door open, the monitor shuts down. Opening the laptop door causes monitor to re-display.
The "Intel Graphics Media Accelerator Driver for mobile" (version 7.14.10.1272) options are set to Monitor (setting to Notebook does what it's supposed to). Using the Hot Keys to swap back and forth works as long as notebook door is open. Close the door, and I cannot get the monitor to display.
...More info: Restarting the laptop fixed the problem. Of course tomorrow we will see what happens when I connect to the 24", and then back to the 17" monitor. I hope restarting every time is not the key. That takes too long.
Any suggestion?
You could try updating your graphics drivers. Find your card in Device Manager, right-click on it, and select Update Driver Software.
    Jonathan King
    AMD Athlon Dual Core Processor 4850e overclocked @ 2.92 GHz
    ASRock A780 FullDisplayPort
    6.0GB Dual-Channel DDR2 290MHz Crucial Technology
    ATI 3200 (onboard), nVidia 7200 GS (PCIe)
    17" Cybervison ds69T, 17" Starlogic
    1024x768
    WD 320GB SATA, Hitachi 1TB SATA
    Antec ea-430d 430W
    Antec 300
    stock cpu, 120mm rear, 140mm top
    Microsoft Wired Desktop 500 (USB)
    Microsoft Wired Desktop 500 (PS/2)
    9.32 Mb/s download; 0.36 Mb/s upload
    Other OS's: Windows 7 Professional x64, Windows Professional x86, Ubuntu x64
Update... I found an explanation for the problem and also a solution:
Whenever I shut the laptop door, Vista redirected the screen to the monitor. However, it was using the last-used settings, which were for a 24" wide screen, running 1920 x 1200. BUT the monitor at home cannot display anything at that range, and so it displays an "out of range" message.
At that point, I could use the graphics "hot keys", ctrl-alt-f3, to direct output back to the laptop. Then, right-click on the screen, choosing Graphics Properties, Display Devices = Monitor, then Display Settings, changing Screen Resolution to the 1280 x 1024 recognized by the smaller monitor, and then click OK. It works!
Then when I connect to the 24" wide screen, it starts up with the 1280x1024, and I go through the above process to change it to the 1920x1200. IF I remember to set it back to 1280x1024 before hibernating, I can take the laptop home and start up with the monitor displaying perfectly.
Hope this makes sense.
It Makes perfect sense glad you got it sorted and thanks for posting the results back
    Intel Core i5 2400 @ 3.10GHz
    Foxconn H67MP-S/-V/H67MP
    8.0GB DDR3 @ 665MHz (2GBx4)
    AMD HD Radeon 6870
    SMB1930NW (1440x900@60Hz)
    Novatech Night
    Dell HID-compliant mouse
