Laptop using 24" monitor question...
mcforyou
Hi, I didn't know where to put this, so I hope this forum is okay. I have an HP G60 laptop with vista home premium, and I recently bought a 24" monitor, only to come to find out that my laptop doesn't come NEAR to providing enough pixelization to make the 24" monitor run at it's full potential. Is there anything I can do about this to make it run in it's full potential? Thanks!
    HP G60-230us notebook
    3 gb
    320 gb
    broadband
hm.... other than upgrade your ram..... there is nothing :(
    AMD Athlon X2 5000+ @ 2.6Ghz
    Acer Micro-ATX Motherboard
    ATI HD3870 with 512mb GDDR4
    Realtek HD 7.1 Onboard Sound
    22" Acer X223 Widescreen
    1680 X 1050
    ULTRA X3 600 Watt Modular
    Microsoft Sidewinder X5
    Microsoft Sidewinder X6
    6 Mbs Down 1 Mbs Up
What exactly do you mean by 'run at it's full potential' ?
Is it:
A) It's not set it to it's native resolution of 1920x1200 or 1920x1080 which either results in a screen with 'borders', or it's outputting at the same res as the laptop which results in a 'fuzzy' picture.
or
B) Games and apps struggle at 1920x1200/1080
If it's A - then it sounds like it's in 'cloned mode' (when plugged into the laptop, the desktop and taskbar appears on both the laptop screen and the 24")
If so, you need to set it to 'Extend the Desktop onto this monitor' to be able to independently configure the resolution.
(right click on the desktop, select personalize > Display Settings )
If the monitor came with a disc, make sure you install any drivers for it.
If it's B - then there is not much you can do.
    i7 3770K HT ON 4.7GHz
    P8Z68 Deluxe Gen 3
    8GB G.Skill Ripjaws X 2133mhz
    X-FI Forte + ATH-AD900
    1920*1200 / 1920x1080
    Corsair AX1200W
    Lian Li PC-V1020A
Ok, I don't have it hooked up yet because I am waiting for the keyboard, but when I look at my screen resolution settings, the lap top only goes to 1366x768 pixels, and my 24" monitor needs 1920x1080 to give it the best resolution. When I asked HP before they said changing my graphics card would do it, but they couldn't even tell me how that worked, they said they would email me about it, but they never did. Is there a way I can use the monitor to it's full pixel potential?
    3 gb
    320 gb
    broadband
=====QUOTE=====
Mobile Intel® GL40 Express Chipset with integrated 3D graphics, featuring Intel® Graphics Media Accelerator 4500M (Intel® GMA 4500M) with up to 1759 MB of Intel® Dynamic Video Memory Technology 5.0 (64 MB of dedicated video memory, up to 1695 MB of shared system memory), supporting Microsoft DirectX® 10
Dual independent display support
16.7 million colors
External resolution/refresh rate:
2048 x 1536: 75/60 Hz
1920 x 1440: 85/75/60 Hz
1920 x 1200: 75/60 Hz
1920 x 1080: 100/85/75/60 Hz
1680 x 945: 100/85/75/60 Hz
1600 x 1200: 120/100/85/75/60 Hz
1600 x 900: 120/100/85/75/60 Hz
1400 x 1050: 85/75/60 Hz
1366 x 768: 85/75/60 Hz
1280 x 1024: 120/100/85/75/60 Hz
1280 x 960: 85/75/60 Hz
1280 x 768: 85/75/60 Hz
1280 x 720: 100/85/75/60 Hz
1024 x 768: 120/100/85/75/60 Hz
800 x 600: 120/100/85/72/60 Hz
MPEG-2/DVD decoding
WMV9 (VC-1) and H.264 (AVC) decoding
===UNQUOTE=====
You cannot 'change' a netbooks graphics card without replacing the entire mainboard. Luckily you don't have to.
The reason that it is currently maxing out at 1366x768 is because that is the netbook screens max resolution.
If you follow what I mentioned in my first post, you will be able to use the 24" @ 1920x1080
    P8Z68 Deluxe Gen 3
    Corsair AX1200W
    Lian Li PC-V1020A
As usual, the HP technical support was completely useless. Smarteyeball is right. As soon as you attach it, it will work. No need to panic.
    Dell
    Q6600
    HP w2207h
Thanks so much guys, when the keyboard gets here and I hook it up, I'll let you know what happens!
    3 gb
    320 gb
    broadband
Good luck :)
    P8Z68 Deluxe Gen 3
    Corsair AX1200W
    Lian Li PC-V1020A
Well, for a day I was worried! I took it right out of the box, tried to use it, it was all wacked out magnified, wrong colors, all crazy, the installation disk was useless, and the users guide was no help either. I finally called SAMSUNG customer service, and went through three levels of technical support to get to the guy who finally told me all I had to do was Push the FN key, (Which I had NEVER used before), and F4, and PRESTO!!! It's the FULL color resolution!! 1980x1080, and BEAUTIFUL!!!! UNREAL!! Lets see if I can post a pic.... Not a great pic, but WOW, this monitor is BEAUTIFUL!! 24 inches almost seems too big!!
    3 gb
    320 gb
    broadband
This is a wonderful story. I am glad you are so satisfied with the result. I am trying to talk the wife into getting at least a 20" for her 14" laptop. But she does not want it. Maybe I can convince her when I show your picture.
    Dell
    Q6600
    HP w2207h
Yeah, the thing is when your used to a small screen you don't think you need a larger one, and really you don't, but when you GET IT.... that's a different story! The picture is so clear and crisp too! It was too bright, I had to turn the brightness down, but that was easy... It's amazing!!
    3 gb
    320 gb
    broadband
I cannot work on those laptop screens anyhow. My vision is too bad. I have 22" screens since 2 years - but 24" would be even better. I think Samsung makes good screens. i have HPs.
    Dell
    Q6600
    HP w2207h
