wicked69ng
Was given a "new" computer from a friend. A discription of my problem is as follows with hardware discriptions to follow after that.
I currently have two monitors. The back of this computer has 2 video ports. 1 of which is DVI-I (4 pins next to the long pin) and 1 DVI-D (Does not have 4 pins). I currently have 1 17" VGA ONLY Monitor, and one 19" DVI-I, VGA, S-Video. I have 1 VGA cord, 1 DVI-D cord, and one DVI-I to VGA Adapter.
Both Monitors work in the DVI-I slot. Obviously I can only connect the VGA to the DVI-I slot. I have been on intels support site for hours checking drivers, updating bios, etc. Can provide screen shots of anything needed to help with this.
When I right click and go to "Personalize" I can click on the "greyed out" Monitor 2, click extend desktop, when I click apply the "working" screen flickers, asks do I want to keep these setting, yet nothing has changed. Once I click yes it returns to display settings and monitor 2 is greyed out again.
Under "Device Manager" under Display Adapters it says "Intel(R) Q45/Q43 Express Chipset", and under Monitors it states "Generic PnP Monitor".
I have tried absolutly everything I can think of and am very desperate to get this resolved hopefully someone can help......
I am running Directx10
I have screen shots of both monitors. To get that I just have to unplug one from the DVI-I and Plug the other in.
If anyother information of Screen Shots are needed PLEASE ASK
Thank you
- Custom
- Intel(R) Core(TM)2 Duo CPU E7400 @ 2.80GHz, 2800 MHz
- Intel Cube Cove DQ45CB
- Intel(R) Q45/Q43 Express Chipset
- Intel 82801JB ICH10 - High Definition Audio Controller [B-0]
- & Hanns.G HX191D 19" LCD TFT & eMachines E17T6W 17" VGA
- Multiple
- Seagate 250gig, a 360 gig, External 1 TB
- PSU
- Unknown
- Case
- Generic
- Cooling
- Unknown
- HP Optical
- Logitech USB
- DSL
