GeForce 7300 LE problem?
Smurfyy
Danny :)
the other day my dad bought me home a new graphic card, installed it and it worked perfect, got the latest drivers from nvidia, sorted. I then decided to take it downstairs and plug it into the tv to see how good it really was. plugged it in via a "nvidia compupack" thing and it worked fine screen res was a tad high, but i could change that to how i liked it, great! took it back upstairs and plugged it in and it worked, so then i think, i have got an old portable dvd player with a "vid in" plug on it, so i assemble a plug from s-video to 3.5mm and it worked. so i reboot it to finalise it.
here comes the problem, it can see the dvd player but wont extend my display onto it, checked the makeshift converter and it looks fine,. when i select the dvd screen it says "this GPU supports a single display, to use two displays on this computer, reboot the computer" so i reboot and its still the same!!
help me please!!
thanks, daniel
    Custom built.
    ASUS M5A78L-M/USB3
    8GB DDR3 @ 1333MHz
    750 watt.
    Foxconn TSAA699.
    4 fans.
