XFX ATI HD 5770 Help!
Kraz
Hi, my recent Nvidia 9800GTX has become faulty e.g. flickering and fragmented screen and the computer wont start up. It is not a Mobo issue since I can enter the BIOS etc. I just bought an ATI HD 5770 and placed it in the computer. Everything runs fine until I choose whether to start it normally or in safe mode as neither option works(It just waits at the screen for hours nothing happens). I cant uninstall the drivers from the 9800 since the comp wont start. Any ideas on getting the new card to work without going to get it serviced etc please. Thanks
Try using driver sweeper in Safe Mode to clean all the Nvidia drivers/software.
(Run Driver Sweeper as admin)
[FONT=&quot] [/FONT]Download and install Driver Sweeper from:
Guru3D - Driver Sweeper
    i7 3770K HT ON 4.7GHz
    P8Z68 Deluxe Gen 3
    8GB G.Skill Ripjaws X 2133mhz
    X-FI Forte + ATH-AD900
    1920*1200 / 1920x1080
    Corsair AX1200W
    Lian Li PC-V1020A
Hey thanks for the reply, that would be a good idea but how do I get into safe mode as my 9800GTX is broken it wont let me get into safe mode it waits at loading crcdisk.sys for hours (fragmented screen with repeats of the words its a mess lol).
(using my laptop at the moment.)
Does your motherboard have onboard video?
I just re-read your first post and I didn't notice the fact that you tried entering safe mode with 5770 installed :o
Since Safe Mode uses the VGA driver, I just assumed it would be fine to use the 5770.
    P8Z68 Deluxe Gen 3
    Corsair AX1200W
    Lian Li PC-V1020A
No, it doesn't :(
I'm sorry to say I'm currently out of ideas. Hopefully someone else can think of something in the interim.
    P8Z68 Deluxe Gen 3
    Corsair AX1200W
    Lian Li PC-V1020A
Hello Kraz,
When in safe mode it lists the drivers it's loading, where does it stop ?, also, remove all but keyboard and mouse USB devices.
If anything is overclocked, set it back to default.
What screen does it sit at when loading, how far in to the process does it get ?.
Was the 9800 at fault in the first place, do you have another PC to try it on ?.
You could try removing all but one stick of ram, i have had Asus boards for years and they can be picky about new hardware.
It may be worth looking to see if the Bios is up to date. (if you update the Bios, do it through EZ Flash in the Bios, not through any software that Asus may have given you).
If you have a Vista disk, you could try a repair install, just to make sure all the system files are OK.
These are in no special order, just things i would do in your position.
Take a look and let us know.
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
what power supply do you have?
    XFX 780i
    4GB OCZ PC2-8500C5 DDR2
    Gainward GTX260/216 SLI
    Creative X-FI Xtreme Gamer
    Dell UltraSharp 2209WA 22"
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
