"Mode not supported" problem
Brutus82
hi all
i shall start from the beginning, went to clean my pc out, as normal, took out my dvi-i adapter, left it on the side....
my boy got hold of it (bless him), couple of pins missing, so i brought a new one off ebay for very cheap talking less than 2 quid (i know !), so while i wait i take out my 7900 GS to clean its fan as its not accessible while in tower.... so the new dvi-i comes , i put card back in, start up and looks ok till i get "mode not supported" on my lcd.. tried few times, no joy.
so card comes out, put vga into onboard, works fine, so monitor seems good. deleted nvidia drivers, switched off put card in, adapter, cables, start up then card installs itself, restart , all good so far, apart from old drivers and crap resolution.. i noticed in my device manager there was no "Monitor Tab", after a brief search , i updated and i now have a Monitor tab and have "Generic PnP monitor" in the section
Then i update to newest drivers, after i restart i get the message "Mode Not Supported" with H 75.0 hz / V 60.0 hz under it
i tried this with several drivers back to july 2008, still no luck, and tried all resolutions also tried it with my old crt monitor and i get a "frequency" message
so could this be the cheap ass adapter? , my card ?, bit to hard a clean and broke it ?
sorry for the long post, wanted to give all info possible
hope someone can help me out, thanks
    Intel® Core™2 Duo Processor 6400 @ 2.13ghz
    2GB
    Geforce 7900 GS
    1280 x 1024
    Maxtor 500gb SATA
    Logitech MX100
    Saitek Eclipse
    8mb
it looks like its because of the 75hz pre set your monitor is most likely 60
if you tap F8 at bootup you are presented with a screen of options (safemode) one of them is to boot at 640x480 60hz (use arrow keys to navigate enter to select)
will it boot like that? (obviously after you have installed drivers)
It may just be a faulty adapter
    XFX 780i
    4GB OCZ PC2-8500C5 DDR2
    Gainward GTX260/216 SLI
    Creative X-FI Xtreme Gamer
    Dell UltraSharp 2209WA 22"
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
thanks for the reply
i still get the "mode not supported" even when i do that, seems whatever i set my card up as , when i reboot it goes to the highest, which obviously my monitor cannot handle
i shall try to get a new adapter today and try that :/
thanks
    2GB
    Geforce 7900 GS
    1280 x 1024
    Maxtor 500gb SATA
    Logitech MX100
    Saitek Eclipse
    8mb
with a quick side question, is 9500gt a decent upgrade from a 7900gs ?
just lookin for a cheap upgrade really
thanks
    2GB
    Geforce 7900 GS
    1280 x 1024
    Maxtor 500gb SATA
    Logitech MX100
    Saitek Eclipse
    8mb
thanks
it will definately be faster but by how much is hard to say you would be far better off getting an 8800GT if you can find one , the 9500 is a dog its basically a rebadged 8600
how much cash do you have and what power supply?
oh and yes try another dvi adapter first and buy it somewhere else ;)
edit.............this is a nice card
http://cgi.ebay.co.uk/XFX-GeForce-8...s_TW?hash=item19b677fd07&_trksid=p3286.c0.m14
ive just given my old to my cousin an hes playing COD5 maxed out at 1280x1024 4AA 16AF
theres a few of em on ebay you if you decidede to go for one you want the GT NOT the GTS or GS and you want to go for one with 512mb memory and dont pay more than 75 quid for it ;)
    XFX 780i
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
i have a 400w supply and will spend upto £100, only play WoW , lotro and will be new swtor
and ya, no more ebay for the pc lol
    2GB
    Geforce 7900 GS
    1280 x 1024
    Maxtor 500gb SATA
    Logitech MX100
    Saitek Eclipse
    8mb
ok thanks for your help, ive ordered me a new dvi-i adapter from dabs, see were i get..
if i cant get hold of a good deal 8800gt, any other cards about you could recommend ?
cheers
    2GB
    Geforce 7900 GS
    1280 x 1024
    Maxtor 500gb SATA
    Logitech MX100
    Saitek Eclipse
    8mb
arg 400w :confused: Now this is fine aslong as you have 22-24 amp at least on the 12v rail , it'll say on the side of your psu . If not you might struggle with an 8800 , i do know a full non overclocked system with an 8800gt in it will draw in the region of 250 watts the card itself drawing about 110 BUT that said a low end 400w psu will struggle (you will get poor performance clock speeds reverting to 2d settings error messages etc)
I cant recommmned you spend your cash on anything till we know the exact specs of your PSU , as i said though if its a decent one you will be absolutely fine :)
EDIT.......if you have a decent PSU
http://www.overclockers.co.uk/showproduct.php?prodid=GX-176-AS&groupid=701&catid=56&subcat=1009
NVidia recommned at least 400w but again you will need a good one
    XFX 780i
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
it says on the 12v = 20a and 5v = 30a
    2GB
    Geforce 7900 GS
    1280 x 1024
    Maxtor 500gb SATA
    Logitech MX100
    Saitek Eclipse
    8mb
maybe an 8800GT wil be ok but i can recommend it mate sorry , i cant be sure a 9800 will struggle , Im not saying it wont be ok (although i dont think it will :( ) what im saying is i cant recommend you spend your cash upgrading with that PSU , however if yuo go for your original choice of a 9500 you will be ok
EDIT...........just one thing do you have two 12v rails? or just one?
    XFX 780i
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
    2GB
    Geforce 7900 GS
    1280 x 1024
    Maxtor 500gb SATA
    Logitech MX100
    Saitek Eclipse
    8mb
erm............no , no and erm............no ;) Im biased though, put it this way i wouldnt touch any of them with yours ;)
Can you stretch to this.............
Coolermaster eXtreme Power 650W Power Supply
two 12v rails 18A on each rail 32A all in
Cooler Master eXtreme Power Plus 650W Power Supply | PSU
its a really really bad idea to try and save cash on a PSU , this one is cheap for what you get though and a trusted name and a fan speed controller to keep the noise down ;)
EDIT........honestly though if you cant stretch to that psu yet wait and save a bit more , if your gonna upgrade your GPU you are gonna want to get a half decent PSU , and as i recommended that one its obviously the right choice ;) ;)
    XFX 780i
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
ye i could probably stretch to that lol, was just tryin to save a few quid, saves the ear ache from the woman lol, but i can wait abit and get one of them..
so a 8800 or a 9800 would run good on that then ?
    2GB
    Geforce 7900 GS
    1280 x 1024
    Maxtor 500gb SATA
    Logitech MX100
    Saitek Eclipse
    8mb
lol without sounding like a total idiot, whats the main things im lookin for in a card, ive been looking at some gts 250, 9800's, 9600's
all similar price, each with specs slightly different to each other
im no hardcore gamer, use my ps3 for that, just MMO's on my pc
confuses me lol
    2GB
    Geforce 7900 GS
    1280 x 1024
    Maxtor 500gb SATA
    Logitech MX100
    Saitek Eclipse
    8mb
what is the max you can afford (after your psu) and ill have look :)
    XFX 780i
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
probably round a 100, obviously less if possible cos if i can get one for cheap (like a 9600 for 60 ish) then ill get me a couple of extra gb for an allround upgrade, but whatever , like i say im not up on the new stuff
    2GB
    Geforce 7900 GS
    1280 x 1024
    Maxtor 500gb SATA
    Logitech MX100
    Saitek Eclipse
    8mb
XFX ATI Radeon HD 4870 1024MB GDDR5 PCI-Express Graphics Card
im going for the best possible in yuor price range but if your looking to save cash then i suppose a 9600 is cheap ( their really sh!t though ;) ) youll get twice the FPS at twice the resolution with the ATI
what are your full system specs at the moment?
oh and do what i do , lie to your wife about how much stuff costs , she thinks my GTX260 Golden sample was 60 quid ;)
    XFX 780i
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
oh ok, was gonna ask what is the better choice, nvidia or ati ?
ive updated my system spec for what i got now, the psu is a standard 400w that the custom shop fit, same goes for the motherboard without me digging around
thanks for your help so far by the way, much appreciated, and to my origanal problem with the adapter, still waiting delivery :/
    2GB
    Geforce 7900 GS
    1280 x 1024
    Maxtor 500gb SATA
    Logitech MX100
    Saitek Eclipse
    8mb
If you play World of Warcraft, a 9600GT will be enough, but with that PSU, keep what you have. As to the card, try a new adapter. If the monitor worked over VGA, then its fine, so it might be an adapter. Also update your monitor's drivers.
    Sony Vaio Z46GDU
    6GB DDR3 1066MHz SDRAM
    13.1" WXGA True Colour Tough
    1600x900
    320GB SATA 7200RPM
    1MB/s
No problem :) as for which is the best.............in my opinion its NVidia al the way , im not an ATI fan , but i have to recommend to you the fastest and best card in your price range and the 4870 is it :p
    XFX 780i
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
