nVidia Control Panel issue - STUMPED :(
shaere
For days I've been trying to get to the bottom of a problem with the nVidia Control Panel stopping working. I put all my system details in my profile here, but to be brief I am running Windows Vista Home Premium 64 bit and the card is a Gigabyte nVidia 9800GT with 1GB of video RAM. I have installed the drivers that originally came with the card, the updated drivers from the manufacturer's website, as well as most of the latest nVidia drivers directly from nvidia. All of them give a similiar result. when I try to open the nvidia control panel I get a message simliar to the following:
Microsoft Windows
NVIDIA Control Panel Application, 2.7.150.02 has stopped working
Windows can check online for a solution to the problem
-> Check online for a solution and close the program
-> Close the program
View problem details
Problem signature:
Problem Event Name: APPCRASH
Application Name: nvcplui.exe
Application Version: 2.7.150.2
Application Timestamp: 4a71410c
Fault Module Name: NVCPL.DLL
Fault Module Version: 8.15.11.9056
Fault Module Timestamp: 4a71565d
Exception Code: c0000094
Exception Offset: 00000000003bcef0
OS Version: 6.0.6002.2.2.0.768.3
Locale ID: 1033
Additional Information 1: a380
Additional Information 2: 95589421f8cb038cea84d629df35ba26
Additional Information 3: b898
Additional Information 4: d114597e43763414798cec55ff512d18
Unfortunately checking online doesn't give a solution. The only thing that changes is the Application Version (depending on which driver I was trying out at the time) and of course the Time stamp. I have tried driver cleaners, installing in safe mode, the works. At this point I'm frustrated to TEARS!! I have NO idea what to try next and Gigabyte (who makes my card) apparently has no phone tech support, and hasn't replied to any of my inquiries about fixing the problem. I do need the nvidia control panel to make adjustments to the video as my system is connected via HDMI to my 42" flatscreen 1080p HDTV. With my old ATI 3650 I installed the latest drivers and I had perfect 1080p video. Something with nVidia drivers and Vista 64 bit seems to simply not work.
Thanks in advance for any help you can give! :D
UPDATE: if I connect the nvidia card with VGA, the picture looks HORRIBLE but the control panel comes up. :( If I connect DVI to HDMI or HDMI to HDMI the error message comes up.
    HP Pavilion Elite m9426f
    Intel Core 2 Quad CPU Q6600 @ 2.4 Ghz
    Asus IPIBL-LB
    8 GB of PC2-6400 RAM
    Gigabyte GV-N98TOC-1GI Rev. 2.0 (nVidia geForce 9800GT)
    onboard Realtek Audio CODEC: ALC888S
    Proscan 42LA45H (full 1080p HD)
    1920 X 1080 (1080p)
    Single Drive 640 GB
    Rosewill Stallion Series RD500-2DB 500W ATX12V Power Supply
    HP m9426f standard case
    case fans/power supply fan/CPU fan/GPU fan
    Logitech MX Revolution
    HP standard
    Cable - 20mb down, 2mb up
Hi shaere and welcome to Vista Forums :party:
This does sound as though it is a bug in the driver software. I suggest that you fill in this form NVIDIA GeForce and ION Driver Feedback and please keep us posted with what you provided to them, and also on their response.
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Gigabyte IF233
    I5 3570K
    Gigabyte Z77-DS3H
    Gigabyte Geforce GTX 660 TI
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
