I have a really odd wallpaper issue that crops up with my multimonitor setup when I have different resolution monitors.
The prologue: I recently decided that my work-machine needed a third monitor. I also decided to upgrade my video cards while I was at it. (Hey, I'm tired of lagging in FPS's during office fragfests.) So I purchased a pair of GeForce GTS 250's and a third monitor, which runs at different resolution that my other two.
GTS250 #1: primary monitor (1680x1050) & secondary monitor (1680x1050)
GTS250 #2: tertiary monitor (2048x1152)
Which is set up like so:
I have taskbars enabled on monitors 1 & 2, but not on #3.
Ok... Here is the oddness: When the third monitor is enabled, the wallpaper that is displayed underneath the translucent taskbars is the incorrect area of the wallpaper. Both taskbars are for some unknown reason using an area of the wallpaper that is flat wrong.
Here is a picture of the wallpaper with only monitors 1 & 2 enabled. Notice the translucent taskbars showing the correct stuff underneath them. This is how the taskbars should appear.
And here is what happens when I enable monitor 3. Notice that the taskbar on monitor 2 is "borowwing" part of the wallpaper that displays on monitor 1, while monitor 1's taskbar is doing the same from the wallpaper showing on monitor 3 (which happens to be blackness).
Obviously, this is not a major problem.. it's just ... screwy.
Anyone out there in multi-monitor-land have any ideas what the problem is and/or how to fix it?
Thanks,
-ltwally
Thanks,
-ltwally
