Problem Counter-Strike
CiuFuLiXx
Hy 2 all :)
I have a problem...i play Counter-Strike...and i need more and more FPS !
I have only 60 FPS....and it's not constantly....All settings on video card NVIDIA GeForce 6100 nForce 400 it's changed to high performance...and v-sync OFF..
I have Sempron 3000+ 2GB RAM...video card it's onboard 256 mb
P.S - When i run CS i have only 30 process open i think it's good that :D
Sorry for my bad english !!! Anyone can help me ? :D
    AMD SEMPRON 3000+
    2 GB RAM DDR2
    Nvidia GeForce 6100 nForce 400
Hello CiuFuLiXx,
When was the last time you updated the driver's ?, you may need to update them. I would do that first and see how the FPS are then. Also is this Counter-strike on Steam ?, Below are the spec's you need. You may need to lower the setting's a bit to get a good frame rate. Post your result's, good luck.
Minimum: 1.2 GHz Processor, 256MB RAM, DirectX 7 level graphics card, Windows 2000/XP, Mouse, Keyboard, Internet Connection
Recommended: 2.4 GHz Processor, 512MB RAM, DirectX 9 level graphics card, Windows 2000/XP, Mouse, Keyboard, Internet Connection
    Self Build
    QX9650 (black box) 3.0GHz@3.9GHz
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
Drivers are updated last on nvidia download center !
Is counter-strike on STEAM !
Running windows vista home premium 32 byts
Procesor AMD Sempron 3000+ / 2GB RAM DDR2 800mhz / DirectX Level i don't know
Speed connection is good :)
    AMD SEMPRON 3000+
    2 GB RAM DDR2
I dont think you will get an awful lot more out of your system than your getting now, i know CS is an old game, but CS source, going through steam, is still pretty heavy on the system, try turning down the graphic's a bit and see if that help's, it could also be the server's you are using. :(
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
