External Monitor, extreme heat issue
tatz93
I Tried
My laptop is a Compaq Presario F504EA. I have had an external 19" LCD Monitor running sometimes in parallel and sometimes independantly with the laptop. It has its own Power supply, and is only connected to the laptop through a VGA cable.
I was wondering if this could cause the laptop to extremely overheat. With this, the laptop would be un touchable on the bottom side due to extreme heat.
I had also recently upgraded my ram from 1 to 2GB. Would this of had an effect on the heat aswell ?
It is currently in repair due to my keyboard being intermittent along with my wireless; i believe the heat as melted joints or something on the motherboard.
Thanks
Oliver
    AMD X2 1.6 GHz
    1 GB DDR SODIMM 200 Pin
    10mb/s
when was the last time you spray dusted the laptop, that should help the heat issue. but adding more ram should not cause any more than normal heat, the extra monitor might cause more heat cause of the extra power going through the video card, but it should not make it untouchable.
i would try to spray dust the vents and also check to make sure all the fans are working.
    CUSTOM BUILT BY ME
    8BG PC5300 4 x 2GB OCZ
    Onboard 7.1 HD AUDIO
    55" Vizio LCD
    1600 x 1200 HD
    GENERIC
    MICROSOFT WIRELESS MOUSE
    MICROSOFT WIRELESS KEYBOARD
    CABLE 15MBPS
Thanks Fadedrs for the reply.
I have this air canister which sprays the dust out. I have started to do this every other week or so.
It is currently out for repair and hopefully being fitted with a new fan. I will have to wait and see and hope the problem is resolved.
Cheers.
Oliver
    AMD X2 1.6 GHz
    10mb/s
