HELP! Sudden Low Resolution and Pixelated Screen
Nikky8000
ok, out of no where my screen gets these pixelated red lines across it. I thought it overheated so I turned it off for about an hour and turned it on. it is a permanent error. the res is set at 4 bits or something. everything runs fine but the graphics are so messed up. o reinstalled the drivers and nothing changed. so i buy a new graphics card?
your GFX card could well be buggered.....
are you monitoring card temps...??, i know you say it artifacts straight away, but it could of been caused by heat & a lack of thermal paste (as it dissipates over time)
what card is it....???
how long have you been running it..??
enter windows ''safe mode'' & see if the artifacts are still present..??
:)SK
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    8GB 1066mhz buffalo firestix
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    Arctic cooler pro 775
    logitech cordless optical
    logitech EX110
    2mb
