Problem with screen position changing incorrectly
fields999
Hi
I have a problem that involves my screen position to move a small amount upwards sometimes.
Im not sure why it does it exactly but, for example, i may be running a full screen application and when i exit it, my screen position will be a bit higher, cutting off a small part of the top of the screen.
The only thing i can do to this is manually position it back down again. Another thing is its not just happing with a particular application, it happens with many.
Does anyone know why this is happening and what i can do about it?
Thanks
    HP / Custom Build
    AMD Phemon 8650 2.3ghz X3
    Nvidia nForce 720a
    8GB DDR2
    ATI Radeon HD 4650 1GB
    22" HP w2216v
    Hitachi 500gb - Seagate 500gb - Western Digital 1TB
    Cooler Master 600w
    HP
    3x 120mm 1x 90mm 1x 80mm Fans
    Microsoft Explorer Mouse
    HP Multimedia Keyboard
    24mbit
