ATI Radeon hd 3200 HDMI problems
zrenzi
Hello,
I am hoping to find some guidance on how to view the contents of my laptop on my television. It seems straightforward, but I can not seem to get it to work. I have a Panasonic TH50PX80U (720p) plasma television and HP Pavilion dv 7-1135nr laptop with an ATI Radeon hd 3200 graphics card and the Catalyst Control Center 8.4 software and drivers. I am running on Vista Home Premium 64 bit edition. My TV does not have a PC input, so I am trying to connect via the HDMI port. I have tried to start the laptop with the HDMI cable plugged in and the TV on the HDMI component. I have tried hot plugging the HDMI cable. I have tried the Fn+F4. I have tried extending my monitor in the display settings. I have tried looking up my HDMI port in the BIOS (I did not find it). I am curious as to whether this is even possible with my TV. I am at a loss; if anyone has any information that would help me it would be greatly appreciated. Thanks in advance.
I know you state you cannot find HDMI in the bios; however, my Asus desktop board (integrated HD3200) shows the hdmi as DisplayPort Config (Enable/Disable) Disable is default. It also states in the book that surroundview has to be enabled under the aperature setting. I have never tested these as I installed add-on card (nvidia 8800) for my build.
Not sure this helps but at least a little more info.
    Home Built
    AMD Phenom II 920
    GB MA790GP-DSH4
    OCZ Platinum 8GB PC21066
    Sappire Radeon HD4830 512
    HDAudio onboard
    Dell 22" Asus 22"
    1680X1050 1920X1080
    Seagate 500GB Seagate 1.5TB Sumsung 500GB WD 74.5 Raptor
    OCz 650watt
    Cooler Master CM690
    6X120mm
    Logitech LX8
    Saitek Eclipse II
    DSL 5mb
    Tweaked by vistax64.com
