Lightning Speed
Hello,
I hope every one is doing great.
I got a small problem which is to extend my desktop into second monitor.
I used to do that in windows XP it was so simple, how ever it seems I got hard time doing it on Vista even thought I never did it on vista before.
I went to Control Panel > Personalization > Display settings, it shows only 1 monitor and saying "(Multiple Monitors) on NVIDIA..."
I'm using Vista-64Bit. And on SLI mode and plugged the 2 monitors on the same graphic card.
I tried Ultramon 3.0.3 but there still a problem, Ultramon detects only one monitor when I'm trying to use the second.
I've been trying to do it in Nvidia software. How ever I ended up switching between monitors only.
I tried to search around and ask around for more than 4 hours, And still no good.
Hope some one could help me to fix this problem, any hints or tips are very welcome.
Thanks in advance, and happy new year
-Scott
-Scott
- Q6600 OCed till 3.3Ghz
- Nvidia XFX nForce 780i SLI
- 2X2GB Corsair DDR2 800Mhz OCed @ 820Mhz
- 2xNvidia 9500 GT SLI OCed @ 730Mhz each.
- Motherboard Built in
- Acer 22' LCD + 18.5 Wide Samsung LCD
- Internal 2x250 GB SATA II Maxtor, External 500GB SATA WD,
- PSU
- 600Watts
- Case
- GIGABYTE
- Cooling
- GIGABYTE Volar CPU Cooler
- Prestigio
- Samsung Pleomax
- 2Mbps
