Standard VGA graphics adapters HELP
johnletcar
When i upgraded my windows xp to vista about 5 days ago it somehow screwed up my computer. My graphics are so bad that i can't play simple games and i know that my graphics card used to work perfectly. I just need to know if it is vista that has changed my graphics card and if it did how can i fix it. Also for Hardware Acceleration, i can not turn it on because i do not have the troubleshoot option in my display settings. My nero will not burn any dvd disc's due to that. Any help will be greatand thankyou in advance. here are my specs:
Video Card : Standard VGA Graphics Adapter
Manufacturer : Intel Corporation (Gateway 2000)
Model : Standard VGA Graphics Adapter
Bus Type : PCI
Refresh Rate (min/max) : / Hz
GPU Information :
Number of GPU : 1
Codename : Extreme Graphics
Bus : 64-bit
Memory Type : DDR
GPU Frequency : 200 MHz
Texels : 400 MTexels/s
DirectX Support : 6.0
Video Bios Information :
Date : 10/25/20
Version : Hardware Version 0.0
Driver : 6.0.6000.16386
General Features :
Pixel per inch : 96x96 dpi
bits per pixel : 16
Colour Bits/Planes : 1
Brushes : 4294967295
Pens : 4294967295
Markers : 0
Device Fonts : 0
Device Colours : 4294967295
Clip Output to Rectangle : Yes
Hardware Acceleration : No
Physical Memory : 1024 MB (2 x 512 DDR-SDRAM )
ALSO here is my info on my dvd drive
HP DVD Writer 1040r ATA Device
General Information :
Disk Type : CD-Rom Data
Peripheral Type : ATAPI
Model : HP DVD Writer 1040r
Recordable : No
Bus Type : PCI
GPU Information :
Number of GPU : 1
Bus : 64-bit
Memory Type : DDR
Date : 10/25/20
General Features :
bits per pixel : 16
Pens : 4294967295
Markers : 0
Device Fonts : 0
Recordable : No
Hi johnletcar,
Have you run the windows experience index yet? Do that and make sure you have your display set to 32 bit.Right click on the desktop and go to display properties. Check the Device Manager and see if you have any problems in there. Maybe you can check to see if you have the latest driver updates.
Go to the control panel-system and run the WEI.
    Airbot 2.0
    EVGA Nvidia GTX 480 -Fermi
    ASUS Xonar D2X
    1920x1080@60hz
    Corsair HX1000W
    Cooler Master HAF 932
    Logitech Wireless MK700
@ Johnletcar
How old is your video card?!
Bus Type : PCI
GPU Information :
Number of GPU : 1
Bus : 64-bit
Memory Type : DDR
DirectX Support : 6.0 --- we're up to 10 now! (Vista)
General Features :
bits per pixel : 16
Pens : 4294967295
Markers : 0
Device Fonts : 0
You need a new video card. Sorry, you do. Vista desktop won't even right with that card, certainly not Aero. You don't have to mortgage your house to get one, but get a new video card. Your problems will go away, in this area.
    Intel D975XBX2
    ATI Radeon HD 4890 (1GHz)
    hp w2207h (22" widescreen)
    1680 x 1050
    Antec Neo HE 550
    Antec P182
    Zalman CNPS9500 AT
    Logitech MX Revolution
    Logitech Wireless Wave
PS, judging by the age of your card, I'm wondering about your computer...
edit - You also don't have any hardware acceleration on that card
    Intel D975XBX2
    1680 x 1050
    Antec Neo HE 550
    Antec P182
    Zalman CNPS9500 AT
Well i purchased my computer in 2004 and i upgraded my RAM before i purchased Vista so are all the problems are because of my Video Card?
Thanks to those who replied to this thread and, Also will my computer take any Video Card? Sorry about the all the questions but im kinda new to this hardware thing.
It's kind of hard to recommend a video card when I’m not sure of what type VGA bus slot you have? Your current card says PCI, but I don’t want to assume.
Also, did you install any video card drivers? And can you tell us what kind of motherboard you have?
And did you have someone look over your computer before upgrading to Vista? Again, judging from your video card, I have a concern that you may not have enough system to run Vista.
Lastly, if you're unfamiliar with your computer then I recommend you have someone look it over and give you a good assessment of what you may need, including the video card.
Let us know.
    Intel D975XBX2
    1680 x 1050
    Antec Neo HE 550
    Antec P182
    Zalman CNPS9500 AT
