JamesDean59
Hey everyone,
I've been having this system lock up problem on my PC.
System:
350watt power supply
Asus M3A78-EM
AMD 5200X2
2GB OCZ Platinum DDR1066
Maxtor 320GB PATA
NEC DVDR
The problem occurs when I installed an 8500GT Nvidia graphics card. The system would run for a little then completly lock up. All I would be left with was an EventID: 6008 in the Event Viewer once I reset.
Once I remove the 8500GT and run on the onboard 3200HD drivers all is well.
Nothing locks up the system responds fine.
I dont think the system is infected with anything as this is a fresh install on a fresh hard drive. Previously the system ran with XP on a different hard drive (120gb, the 320 was storage) and had no trouble with lockups.
I'm not sure what the problem could be. Originally, I thought it might be power supply--but after trying a 430watt nothign changed. A friend of mine suggested drivers. All mine are up to date. Hopefully someone here could help.
Thanks,
Kris
System:
Asus M3A78-EM
AMD 5200X2
Maxtor 320GB PATA
NEC DVDR
Thanks,
Kris
