Geforce 9800 GT Resolution Problem
pocketboy
Hello!
I just bought a new computer and assembled it myself. I got everything to work exept i can't change resolution and is stuck on 800x600. I downloaded all the graphics drivers and everything but still it won't change.
my setup is:
motherboard: Elitegroup A780GM-A
processor: AMD Athlon 64 x2 5600+
Graphics Forsa geforce 9800 GT 512mb
Memory: 4gb DDR2
any chance you can get into your device manager? if you can, have a look to see if your Gfx is installed and if theres no errors with the drivers, and any chance of a pic?
    Intel Q6600 @ 2.8GHz
    Evga NF78-CK-132-A 3-Way SLI
    EVGA 560 GTX SC FTW 1GB
    Antec 900 Gaming Case
    Logitech generic keyboard
    16Mb Sky bb
I have the same problem it's XP Pro SP1 stuck on 800x600 4Bit color. Using SP2 or higher and vista fixes the problem i've read some where else.
AMD Phenom X4 9650
Inno3D GeForce 9600 GT 512mb
    AMD Phenom X4 9650
    Gigabyte S-Series, GA-MA78GM-S2H, Rev. 1.1
    2x Corsair 2GB DDR2 (Inc. Heat Sink)
    Inno3D GeForce 9600GT
    1440 x 900
    500GB Maxtor (SATA) 200GB Maxtor (IDE)
    650W
interesting, this is new to me, however, i have had a look on ECS' website, and interestingly this popped up,
Due to the DRAM maximum size is 2GB at present
and you need to make sure you have disabled the onboard ATi graphics.
    16Mb Sky bb
http://pici.se/pictures/kKECMMzHD.jpg
When i have not installed any drivers this is what i can see. Chipset is Nvidia so must be my geforce. Can it be i installed the wrong drivers? I formatet my hdd and reinstalled vista with english (US) settings and did not install the japanese nvidia drivers that comes with the cd. Downloaded latest nvidia drivers for 9-series, English (US), Vista x64. Hope this is gonna work.
Edit: Nope, same problem...
Edit: Yes!! I dled an older version of the driver. Works perfectly now! Thank you for taking time and helping me though ^^
Hello,
I have the exact same problem. I am running W7U x64 and everything is working fine except for my nVidia GeForce 9800GT. It can only run in 800x600 and nothing else. I have tried updating all drivers (including "unrelated" ones, e.g. network) and BIOS but still, the only supported mode is 800x600.
I have tried using a GeForce 7600 (also PCI express) and that works fine, with all drivers tested (basically the latest 195.62 and the oldest I could find, 181.71).
Any help would be highly appreciated.
hi i have the same problem Peudada me say that drivers use? please
