Pixel lines problem
Kavoc
Ok, I've done research all over the place that I can think of before coming here. I looked on here and found a few things like it, but not what I have. This has only been happening since I reformated my hard drive 2 times in a week.
These lines usually only show up in my files and programs like the one above, but sometimes they show up in my Firefox as well. I can see them popping up and going away as I'm writing this. They last about 2-10 seconds so far. It doesn't seem to be getting any worse as the last week has gone by, but I'm curious why this is happening and if anybody can help me. The picture is blurry much worse than my screen looks, just fyi. I've got a 17" Plasma LCD.
I've also got a few others from Fallout 3 white load screens that I'm going to post that are not the same, but are happening and may help.
http://i10.photobucket.com/albums/a138/EternalStargazer/ScreenShot0.jpg
http://i10.photobucket.com/albums/a138/EternalStargazer/ScreenShot1.jpg
http://i10.photobucket.com/albums/a138/EternalStargazer/ScreenShot2.jpg
http://i10.photobucket.com/albums/a138/EternalStargazer/ScreenShot3.jpg
    Intel Core 2 Duo
    Nvidia 780i SLI
    4GB 7200 RPM
    Geforce 8800GT
    17" Plasma LCD Westinghouse
    Hitachi 500G
    Smilidon Raidmax
    Coolmaster (Along with two aftermarket fans)
    Razer Lycosa
i dont think its anything to do with you formatting your hard drive, but have you full formatted or quick formatted? that may cause corruption, full format will take about 20 mins to 1 hour to complete?
    Intel Q6600 @ 2.8GHz
    Evga NF78-CK-132-A 3-Way SLI
    EVGA 560 GTX SC FTW 1GB
    Antec 900 Gaming Case
    Logitech generic keyboard
    16Mb Sky bb
Hi Kavoc,
This is indeed puzzling. It is unlikely to be the result of you formatting your HDD as I would expect that you would have other operational issues, but rather your connection between your graphics card and the monitor. You might like to check these, and set your graphics refresh frequency to 60Hz to see if that makes a difference. From your other photobucket images, I notice that the graphical defect is in the same place and of very much the same pattern. It looks as though you are having colour bleeding in certain areas of the screen, the amount and extent of which is dependant on the image being displayed. Do you use your monitor as a TV as well, and, if so, are you getting similar graphical distortion?
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Gigabyte IF233
I reformated with the quick delete of the partition option then format when you go to install a new OS.
I've always had problems with my monitor and GPU connection. My screen turning blue here or there and having to move my tower a little to get it to go away. It's mostly gone away since I've learned that's the problem. I've also had the "Video driver has failed but recovered" message a few times where it goes black then comes back. I found, so far, that I had my OC set a little too high, so I backed it down and no more of that.
Setting the monitor to 60 refresh rate didn't help either. =( They are still visible as I type this. The only show up in the white backgrounds, or closer to white. Never while playing games. The vertical ones are different than my diagnal ones from Fallout 3. As in, Fallout 3 has much larger globe looking ones, and the vertical ones look more like pixels are showing up then going away. They show up as usually red, blue, and yellow.
    Intel Core 2 Duo
    Nvidia 780i SLI
    4GB 7200 RPM
    Geforce 8800GT
    Hitachi 500G
    Smilidon Raidmax
    Razer Lycosa
Have you tried an alternative monitor cable? Do you have access to an alternative monitor to see if the fault occurs on that? It could be that the monitor is producing some form of interference which is travelling down the lead and causing problems that way. Just in case it is a driver problem, here is a link to the latest WHQL driver for your graphics card: GeForce Release 180
    Gigabyte IF233
I have an alternate cable I could try. I'll do so after work tomorrow. I keep getting the forceware driver update wanting to install. Media Shield, Ethernet update, things like that. For some reason it won't install. When I was running 32bit it worked fine, maybe it's the 64bit is causing troubles. Either way, that's another discussion completely.
I've got the latest video. I uninstalled old drivers and let it delete the registry entries. Completely wiped and rebooted with EVGA standard drivers. Then installed the new one. So that far, I'm good and the lines are still here. I work with a bunch of copier technicians that are always playing on computers, one even being Vista certified if I remember correctly. Maybe I'll take in the rig to work and see if he will look at it. Of course, if I connect to one of those at work and the lines are there. =)
    Intel Core 2 Duo
    Nvidia 780i SLI
    4GB 7200 RPM
    Geforce 8800GT
    Hitachi 500G
    Smilidon Raidmax
    Razer Lycosa
Hi Kavoc,
Just another thought. What is the exact model number of your monitor? The fact that you said it was working fine when you had 32-bit leads me to think that it could be something as simple as you require the monitor driver. This file is not actually a driver per se, rather it informs the system of the monitor capabilities.
    Gigabyte IF233
dwarf i disagree with your theory, the reason i disagree is that if it was a cable issue, why does it show in screenshots? surely the graphics card will not show corruption but the monitor will. Thats why i believe it maybe something to do with either your hard drive not formatted and showing corruption in a graphics driver or the graphics card maybe on the way out, or it could be as simple as your ram is dying, check all these components and try and get back to us :)
    16Mb Sky bb
I've checked for the monitor, and found mine. I registered the product, since it was never done when I got it. The problem then becomes that it isn't a real one in their system. Any ideas? As for the ram, I was planning to grab a few 2g sticks with the tax return so maybe I'll do that. I've read elsewhere that RAM could be the problem. Dwarf, where could I find monitor "Drivers"? Could I just google it and see if something comes up?
    Intel Core 2 Duo
    Nvidia 780i SLI
    4GB 7200 RPM
    Geforce 8800GT
    Hitachi 500G
    Smilidon Raidmax
    Razer Lycosa
westinghouse don't provide drivers for their monitors, they are HDCP Compatible, Generic PNP only.
    16Mb Sky bb
Those lines usually come from either an overheating or failing video card. So, are you overclocking your video card? Do you have another card to try and see if the problem goes away?
    Intel D975XBX2
    ATI Radeon HD 4890 (1GHz)
    hp w2207h (22" widescreen)
    1680 x 1050
    Antec Neo HE 550
    Antec P182
    Zalman CNPS9500 AT
    Logitech MX Revolution
    Logitech Wireless Wave
And is your case well ventilated?
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech MX Master (shared)
    Logitech G15 (gen 2)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
My video card is OC, I'll try to turn off the profile and see what happens. As for the venting, I've got 7 including the PSU fan. 4 in and 3 out. Love my Smilidon Case. =)
    Intel Core 2 Duo
    Nvidia 780i SLI
    4GB 7200 RPM
    Geforce 8800GT
    Hitachi 500G
    Smilidon Raidmax
    Razer Lycosa
I stopped the OC on my graphics card. My video card is still overheating tho. I've got the fan to 100% and still hitting 68C, which is the point in which my video driver stops working, screen goes black, and recovers. As of right now, I've not seen any lines though.
    Intel Core 2 Duo
    Nvidia 780i SLI
    4GB 7200 RPM
    Geforce 8800GT
    Hitachi 500G
    Smilidon Raidmax
    Razer Lycosa
What your card seemed to be displaying is known as video artifacts. It can be caused by high overclocks, high heat, or a defect. Here's a good article on video artifacts here - Diagnose video card problems by comparing with example corrupted screens
If you're running stable after removing the OC, that's a good thing. I'd leave it that way.
As for the temps, i'd visit one of the Nvidia forums and ask them what the normal temps on that card should be. I know my ATI 4850 runs around 65-68 normal, 85ish on load. That's within ATI's specs, hard to believe but true.
    Intel D975XBX2
    1680 x 1050
    Antec Neo HE 550
    Antec P182
    Zalman CNPS9500 AT
I believe I've found the problem with it overheating because of the OC. Whenever I'd hit a certain temp it would also say the graphics driver failed and it doesn't do that anymore. Even if it goes above the temp it was having problems with before for some reason. I still get the dots every now and again, but I'll just attempt to change ram out when I can get my hands on some. Thank you all for your help!
    Intel Core 2 Duo
    Nvidia 780i SLI
    4GB 7200 RPM
    Geforce 8800GT
    Hitachi 500G
    Smilidon Raidmax
    Razer Lycosa
