problems with Gainward HD4850GS
VitoDonCorleone
i've posted some time ago. The problem was a freezing screen if I used Vista Ultimate x64 with 4GB RAM (Kingston ValueRam 4x1GB). With 2GB RAM on the board everything worked fine.
I thought that my graphics card was the problem (ATI Radeon X1950GT Super) and installed and used XP x64. On XP x64 I had no problems with 4GB and my X1950GT.
On Friday I bought new RAM (Crucial Ballistix 2x2GB) and a new graphics card and now I want to use my Vista x64 again.
But I have a similar issue again. If I try to use Vista x64 with 4GB RAM the screen shows white stripes and Vista restarts the graphics driver every 1-2 minutes. This happens for example when I open the system properties. With 2GB everything works fine again.
I updated my BIOS to version 2.70 and installed newest Catalyst 8.12, SP1 for Vista is installed too.
Do you have any ideas? I think it's the mainboard...it should support 8GB...
Thanks,
Thomas
    AMD Athlon 64 X2 5000+
    Asrock Alive XFire eSATA2 Rev1
    Gainward HD4850GS
    Philips 170S
    Samsung HD501LJ
    Sharkoon SHA500
Hi.
It's really strange. If I login as Administrator all seems to work fine. But if I login with my personal user it loads the desktop and then it looks like following picture:
I activated the Administrator account like you described and installed the 8.6 driver.
Don't understand why it's working under the Administrator account. I tried to create a new user account but there is the same thing as for my personal user.
Only Administrator seems to work fine... :cry:
Hey Thomas,
On your very last post of the previous post you said that yor graphic card worked fine when you were logged on as administrator (Just a normal administrator not this TRUE admnistrator) Is this still the case?
If the answer is yes, I would make only an administrator account.
After reading your previous post I don't think its your mainboard. It sounds to me like software, possibly buggy drivers
I hope this helps
Pooch
    Self build
    Asus M3A32-MVP Deluxe
    8 gig Samsung PC800 RAM
    NVidia 9600gt
    AD1988b
    1680 : 1050 1280 : 1024
    Enermax Chakra
    Easy Line Laser Mouse
    Standard
sorry for the delayed answer. I've tested it with a user (administrator account) but it's not working. With true administrator it seems to work.
After contacting the support I increased the RAM voltage to 2.0V and installed Vista completely new. I don't have all updates installed yet, but I'll post the result of the work. I hope it solves the problem. The support meant it could be a problem if Vista was installed with 4GB RAM and I should only use 4GB after installing SP1.
Thanks so far,
Thomas
    Gainward HD4850GS
    Philips 170S
    Samsung HD501LJ
    Sharkoon SHA500
