I have a HP Pavilion computer that has the video card built into the motherboard, I want to run dual monitors on the computer.
Can I using the existing video card setup and get another video card to run the second monitor, or do I need to get a dual monitor video card?
Or is there any other options for a dual monitor setup.
This computer is not for high speed graphics.
No gaming on this system.
Just need to know the best way to approach this situation or what you would recommend.
Thanks,
OkNowWhat
Thanks,
OkNowWhat
- 2GB
- GeForce 5500 FX
- 200GB
