I have a 9800 GX2 card and always want to run two monitors. In the Nvidia Control Panel set-up under 3D settings and sub heading "Set Multi-GPU Config" I have the recommended option of Multi-GPU Mode, but if I select that, the second monitor stays blank. I assume because my card has two GPU's internally SLI connected and you (to date) can't run two monitors when SLI invoked?
Assuming that is correct
1. Is Nvidia working to overcome this major hurdle of SLI and 2 Monitors?
2. If I use Triple Head to Go, will this allow me to select Multi-GPU and still have two monitors and will I have better performance?
Kotuku
Kotuku
- Intel Core2 Extreme Quad Core
- XFX MB-N790-IUL9 NFORCE 790 U
- 4 Gb (2x2) Gskill DD3 1600
- XFX 9800GX2 Black Ed. 1Gb DD3
- 2x WD Raptor 150 Gb SATA 10000rpm in Raid0 plus 500 Gb Seagate 7200rpm SATA2
