I have a displaying problem
Mr_Observer
Hello everybody,
I am making history now since this is my first participation in any online forum;I usually read only :D.I would like to thank in advance those people who will volunteer to help me out.
A friend of mine came up to me asking for my help with his Acer labtop;it runs Windows Vista Home Edition.His problem is that when he tries to delete some files that he previously stored in the C:\"Account Name",he gets a message saying that the file is unavailable in the specified location.However,that is not my main problem now,because when I was trying to help fix this problem I typed "msconfig" into the RUN box to get the startup utility box and I unchecked some of the background programs to prevent them from loading automatically when the system starts,in order to speed up the system;but when I restarted the system I can see the first screen,which is by the manufacturer of the labtop;then when vista starts loading, the screen becomes black and don't display anything,although I am sure that Vista is loading successfully but I cannot see it on the screen.
I am assuming that one of the programs that I have unchecked is responsible for displaying. I have tried to do a repair installation by using a bootable Vista DVD but I couldn't because I cannot see anything on the screen.I tried logging in on safe mode but that did not work either.
How can I undo the changes that I have made to startup utility.
Your kind assistance is greatly appreciated.
You could try hitting F8 before Vista boots, and selecting "Last Known Working Configuration" or something along those lines.
Good luck
    E6750 @ 3.2GHz
    Asus P5K-e/Wifi-AP
    4x1GB Crucial Ballistix DDR2 800
    PNY 8800GT @ 675/1675/950
    Asus Xonar DX
    Samsung SyncMaster 220WM
    500GB WD SATA II 500GB Seagate SATA II
    700W OCZ GameXStream
    Cooler Master Centurion 5
    Arctic Cooling Freezer 7 Pro
    Logitech G5
    ~3Mb
Thank you for your reply.The first thing that I did was the "Last known working configuration",but it did not work.
What freaks me out is the thought that I won't be able even to do a fresh Vista installation to the labtop.
when i had a similar problem, it was because i had selected an incorrect resolution, as you cant get in to change it, can i suggest you hook up the tv-out and try that. It has saved my 4ss before!
    HP dv6519tx
    160Gig
    Microsoft Trackball
    Depends on the neighbours wireless network
    Asus ROG Striker 2 Extreme
    2 x 2Gb Patriot DDR3
    XFX GeForce 9800 GTX+
    Creative Supreme FX 2
    Neovo F417 17''
    Samsung SP2504C SATA 7200rpm
    Pc Power & Cooling 750
    Coolermaster CM 690
    Logitech G11
    ~1000 Kb/sec
if their tips don't help boot in safe mode and recheck all the apps in msconfig and reboot this should in essence solve that issue.
    me
    intel Q6600 @3.0Ghz
    gigabyte EP35C DS3R
    8 GB OCZ 1066 HPC REAPER
    Sapphire 4870 HD 1024mb gddr5
    lg flatron 20.1
    western digital 350gb samsung spinpoint 120gb
    900w
    thermaltake aguila
    2x 120mm 2x 10cm
