Suggestions for monitor "management"????
stixx
Hello all - I was curious if anyone has any recommendation to better manage my monitor setup. I have a PC that I use for both gaming and VMC. The PC is connected to a 21" LCD monitor as well as a 50" HDTV plasma. The PC and LCD are always on, but I obviously dont have the plasma on 24/7. Using nVidia Control Panel, I can easily setup the plasma for VMC use, but when I change to a different input or turn the plasma off, I have to manually configure the plasma the next time I want to use VMC.
In a perfect world, I think it would be great if I could turn the plasma on, switch it to the VMC "input" and see my VMC desktop with additional PC configuration.
Any suggestions?
    Self built
    Intel 6850
    Gigabyte EP45-DS3R
    Patriot Extreme Performance PC2-8500 (4GB)
    ATI 4850
    Mainboard - Realtek
    Samsung Syncmaster 216BW
    320GB x 1 500 GB x 1 1TB x 3 (Windows Home Server) 500GB x 1 (Windows Home Server)
    Ultra 1000W
    Ultra M923 ATX Full Tower Case
    Logitech G5
    Logitech G15
Any suggestions?
Have you tried UltraMon (free to try)? Realtime Soft UltraMon
Make sure you grab the beta version (3.0.2) as it was built for Vista (and is very stable).
    Intel Q6600 quad
    MSI P6N Diamond
    4 x 1GB Corsair XMS2 PC-6400
    2x MSI NX8600GTS-OC (512)
    1x 150GB Raptor 4x 500GB Barracudas 1x 300GB Barracuda
I have not - I will give it a try tonight.
Thx for the insight.
    Self built
    Intel 6850
    Gigabyte EP45-DS3R
    ATI 4850
    Mainboard - Realtek
    Ultra 1000W
    Logitech G5
    Logitech G15
I think its feature that allows you to create different "display profiles" may be just what you are looking for. UltraMon Features - Display profiles
FWIW - I've used UltraMon both of my multi-monitor rigs for a few years now. It's miles better than using Windows to control multiple displays. And well worth the US $40 IMHO.
    Intel Q6600 quad
    MSI P6N Diamond
