Problems running 32-bit apps on Vista 64
hanneman
When I run 32-bit apps on Windows Vista 64-bit, they work fine but there's no internet connection and when I close them, an illegal operation message is shown.
I tried using Opera and IE (32bit) and both show their "page could not be found" pages, Firefox just shows a blank page and "done" in the status bar.
It's strange, because the only browser that works fine is the IE 64-bit version. All the 32-bit applications have no internet connection (Windows Live Messenger crashes at the beginning).
The problem started suddenly, it was working perfectly when I shutdown last day, so when I woke and booted it, the problem was there.
My network drivers are installed correctly, I tried uninstalling and installing them again, but it didn't work.
So, anyone else had this problem?
How can I fix it?
Thanks!
