sweetypie747
I am not sure what has happened but the following message appears when turning on my comp:
I have the disk but how do i boot from it? I am very worried i've broken my comp for good.
Thanks in advance and i really hope someone can help me!!
Sweetypie747
Windows failed to start. A recent hardware or software change might be the cause. To fix the problem:
1) Insert your windows installation disc and restart your computer
2) Choose your language settings and then click Next
3) Click 'Repair your Computer'.
If you do not have this disc, contact your system administrator or computer manufacturer for assistance.
File: \windows\system32\windload.exe
Status: 0xc000000e
Info: the selected entry could not be loaded because the application is missing or corrupt.
Sweetypie747
