Solved Invisible Problems
Prithvi007
OK, I just created a Folder, named it this character: (invisible) -- (ALT + 255)[Yup. I used the Alt symbols.]
So now that folder has no name.:p
Next, I changed the Folder's icon to "Blank" (Customize--> Icon --> There are four blank icons....I took one.)
So, precisely the folder is invisible now. :eek: The same worked out in windows 8.1. It showed some glitches earlier like turning the icon totally into a black square... But know it's fine.
OK. Now the funny part. I can't rename it back to something in words nor can I delete the folder. It's okay to stay but kind of annoying..
Can anyone help me out? I just want to delete it. :zip:
PS: LOOKS LIKE MOST PEOPLE DON'T BELIEVE THIS! :( Proof:
[video=youtube;5omT3hkZHZI]https://www.youtube.com/watch?v=5omT3hkZHZI[/video]
This is how it looks like, when the mouse pointer is hovered & Properties too.
    Intel Pentium D 3.00GHz
    Intel
    1 GB
    Intel(R) 82945G Express Chipset Controller 0
    1024x768
    4 X 39.0 GB
    Microsoft
    Microsoft
    Download 3 Mbps, Upload 3Mbps
Open up a command prompt (windows key + r; type cmd in the window) and in the black window type in the following:
cd <path to file>
dir (to get a directory listing)
rmdir <name>
    Windows 8.1 Industry Pro x64
    HP Pavillion Elite HPE-250f
    8 gb
    ATI Radeon HD 5770 1 gb ram
    Alienware 25 AW2521HF
    1920x1080 &1680x1050
    1 TB x2
    Dell Poweredge T140
    8GB 2666MT/s DDR4 ECC UDIMM
    1 TB & 360 GB x2
cd <path to file>
rmdir <name>
Thanks for the response! :rolleyes:
I got the directory(to my desktop) opened in CMD.
Using "RMDIR /S" I'm able to delete other folders.(I named a folder "OtherFolder" and deleted it -in the pic)
But, as I said, this folder doesn't have a name at all... So if I leave a blank space for the name and then type "/S", I get a syntax error.
Here's the pic...
    Intel
    1 GB
    1024x768
    4 X 39.0 GB
    Microsoft
    Microsoft
To be more clear to everyone who viewed this post. It just kind of blinks when I try to delete it or when I refresh the Desktop.
A small video...:geek:
[video=youtube;2EjWwYL9HvQ]https://www.youtube.com/watch?v=2EjWwYL9HvQ&amp;feature=youtu.be[/video]
----> I was able to delete the folder I've created in Windows 8.1 64bit with ease. So, does it have anything to do with vista and my PC? :confused:
    Intel
    1 GB
    1024x768
    4 X 39.0 GB
    Microsoft
    Microsoft
Ah! Finally! I got it! I got it deleted! ~PHEW~ I just had to use this command:
ren "<alt+0160>" <new_name>
You don't have to do the renaming stuff in Windows 8. I renamed it successfully. Thank you for your time townsbg.:)
    Intel
    1 GB
    1024x768
    4 X 39.0 GB
    Microsoft
    Microsoft
I'm glad you resolved it. You know doing something like that isn't a good idea. I'm sure you learned a lesson.
    8 gb
    1 TB x2
    Dell Poweredge T140
    1 TB & 360 GB x2
