You should upgrade or use an
alternative browser .
how much should i sell my desktop pc for (help required)
Hi all,
im looking to sell my desktop pc and was looking for some help on how much i should sell it for.
could i get some opinions on what you think would be a good price?
is there a way i can upload my pc specs in a file for you all to view?
No manufacturer- built pc.
2.30 gigahertz AMD Phenom 9650 Quad-Core
ASRock ALiveNF6G-GLAN
4.00 GB
NVIDIA GEFORCE 9400 GT
High Definition Audio Device / NVIDIA Virtual Audio Device
Hanns.G Hi221 [Monitor] (22.0"vis, s/n 902RH3XY01826, January 2009)
1680 x 1050
MAXTOR S TM3250310AS SCSI Disk Device (250.06 GB)
Microsoft USB Dual Receiver Wireless Mouse (Mouse and Keyboa
Optiarc DVD RW AD-5200A ATA Device [Optical drive]HP HP Deskjet F4200 series (DOT4USB)
Fill in
My System Specs below your name on left side.
To do this click on your name at top right, where it says
Welcome, your name
then click on System Specs tab.
and edit the various fields.
When you click on My System Specs, it should look something like this:
Operating System
Windows 10 Pro X64
Lenovo IdeaCenter K450
Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz, 3401 Mhz, 4 Core(s)
16GB
NVIDIA GeForce GTX 750, Intel(R) HD Graphics 4600
Samsung 27" C27F398 Curved Monitor
1920 x 1080 (HDMI)
Samsung SSD 840 EVO 250GB
Seagate ST2000NM001 2TB
Seagate ST31500341AS 1.5TB
500W
Lenovo USB
50MB Down, 10MB Up
Operating System
Windows 7 Pro X64
HP xw4400 Workstation
Intel Pentium D Dual 3.4Ghz
HP 0A68h
5GB
Realtek HD Audio
Acer KN242HYL 24" (KVMS)
1920X1080
Seagate ST3120026As 120GB SATA (boot)
Toshiba DT01ACA200 2TB SATA
Logitech via KVMS switch
Dell USB via KVMS switch
50 Down, 10 Up
Apache Web Server since 2001
I have filled in what I can for now.
Hope this helps enough.
4.00 GB
1680 x 1050
Dual L5639 // i7 950 @ 4.0Ghz
gtx 560 ti // gtx 260-216
Dual 22" // Headless
You know, that's not a bad machine you have there. But I have to second Patonb. PC's lose value quickly. To relate; I had to let go of a fine machine for cheap....Disappointing.....I think a laptop would be different.
I would sell the monitor seperately. That's a goos monitor. For the rest I would try $250.
Dell
Q6600
HP w2207h
2x250GB HDDs
1x60GB OCZ SSD
6 external disks 60 to 640GBs
