Shabakthanai
Without warning, my exterior monitor changed its presentation, and only the right half of my desktop image appears and on the left half of the screen. The right half of the screen remains black and inactive.
At the same time, the laptop operates pretty-much normal.
I have been unable to find configuration settings that will change this problem. I would prefer the extended screen to appear as a clone of the laptop screen, but would prefer to be able to drag a mouse from screen to screen if possible, as well as, open different applications on each screen; also, I would like to drag applications from screen to screen.
In the recent past, I have been able to view a clone image on both screens, however this changed, without me making any changes to configuration, as per, paragraph one of this post.
Is there a way to return monitor settings to default settings. That may provide an acceptable solution.
Thanks for any help you may provide.
System information:
Operating System
Windows Vista Home Premium
Version: 6.0.002 Service Pack 2 Build 6002
Laptop Toshiba Satelite A505 64bit
Processor:
Intel Core 2 Du CPU p7350 @ 2.0ghz
Installed physical memory: 8gb
Virtual memory: 16gb
System information:
Operating System
Processor:
- Toshiba Satelite A505
- Intel(R) Core(TM)2 Duo CPU P7350 @ 2.00GHz, 2000 MB
- don't know
- 8gb
- ATI Mobility Radeon HD 4500 Series
- Realtek High Definition Audio
- duh, it's a laptop
