Vista running very slow. Need some help please.
Rawkfist
I have a Dell Studio 1737 laptop with Vista Home Premium Edition. It is running very slowly. When I try to open programs there is sometimes a long pause before they open. Sometimes when I type in Google Chrome there is lag and long pauses with the keys typing in the letters. I have Defragged, done disk clean up, driver updated and did a hard drive scan. The results of the scan came back that some of the files were corrupt and could not be fixed. What should I do next? I have the original Vista disk. It appears that I have SP 1 installed. I also have scanned for viruses and it is ok. I had Nortons 360 but did a full uninstall and Norton Removal Tool.
Thanks
    Dell Studio 1737
    Intel Dual Core
    2.10 Ghz
    400 gb
The first thing I would do is run a diagnostic on the HD. Usually whoever makes the drive has diagnostic programs available for download on their support page. The first thing is to try to find out if it's hardware of software. So we should wait on the results of the diagnostic.
If you cannot tell from the system info who made the drive usually there's details about all the components in the system for each model. So you can always look your machine up on the Dell site(assuming the drive was never replaced.)
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
Ok I think I got it. It looks as though the hard drive is ST9500420ASG ATA Device. Now I googled this and it says Seagate. So I need to dl the info for this Seagate website and then run the diagnostics?
    Dell Studio 1737
    Intel Dual Core
    2.10 Ghz
    400 gb
Right. The download should tell you what drives it may be used with. It should have a list of Seagate models it is designed to test.
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
I was able to dl and run a diagnostic test through the Dell website for my computer and when it did the diagnostic test it failed the Targeted Read Test and then skipped the rest of the tests. Should I still go to Seagate and try to run a diagnostic test?
    Dell Studio 1737
    Intel Dual Core
    2.10 Ghz
    400 gb
Ok I dl the Seagate diagnostic one for my hd. Its called SeaTools for Windows. When I do a Fix All Test it fails and says;
Unfortunately, your Seagate product has failed an important diagnostic test, possibly caused by problem sectors which are difficult to read. Seagate recommends that you run SeaTools for DOS, which has the ability to repair most problem sectors. SeaTools for DOS may be able to save you from the inconvenience and down time of exchanging the drive. For more information on this subject see our online FAQ:
Should I try to do the SeaTools for DOS?
    Dell Studio 1737
    Intel Dual Core
    2.10 Ghz
    400 gb
Try the easy route. Download the free Crystal Disc. Crystal is a good quick test to see if your hard drive has problems
CrystalDiskMark - Software - Crystal Dew World
I use it about once a month to determine if my Hard drive is beginning to deteriorate. You should use CD on a regular basis and keep your stuff backed up, just in case.
If it is free I would try it.
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
Ok I'm doing the Crystal Disk Mark. After dl it I hit ALL and it's doing its thing. How do I interpret the results? Does it tell me if there is a problem and what the problem is? Thanks.
The SeaTools for DOS is free but it is a bit confusing tbh. I may have to ask someone on their Msg Boards how to do it but we'll see. Thanks so far for all the help guys.
    Dell Studio 1737
    Intel Dual Core
    2.10 Ghz
    400 gb
Just upload a pic of the results
I assume the test is done. Here are the results;
CrystalDiskMark 3.0.3 x64 (C) 2007-2013 hiyohiyo
Crystal Dew World : Crystal Dew World
* MB/s = 1,000,000 byte/s [SATA/300 = 300,000,000 byte/s]
Sequential Read : 60.660 MB/s
Sequential Write : 61.943 MB/s
Random Read 512KB : 23.948 MB/s
Random Write 512KB : 30.347 MB/s
Random Read 4KB (QD=1) : 0.311 MB/s [ 76.0 IOPS]
Random Write 4KB (QD=1) : 0.516 MB/s [ 126.0 IOPS]
Random Read 4KB (QD=32) : 0.589 MB/s [ 143.7 IOPS]
Random Write 4KB (QD=32) : 0.501 MB/s [ 122.2 IOPS]
Test : 1000 MB [C: 16.9% (76.0/450.7 GB)] (x5)
Date : 2014/01/10 18:02:10
OS : Windows Vista Home Premium SP2 [6.0 Build 6002] (x64)
    Dell Studio 1737
    Intel Dual Core
    2.10 Ghz
    400 gb
You have to set the language to English.
It says it is set to English. I tried it again.
Sequential Read : 59.582 MB/s
Sequential Write : 59.598 MB/s
Random Read 512KB : 23.518 MB/s
Random Write 512KB : 29.294 MB/s
Random Read 4KB (QD=1) : 0.310 MB/s [ 75.6 IOPS]
Random Write 4KB (QD=1) : 0.531 MB/s [ 129.6 IOPS]
Random Read 4KB (QD=32) : 0.589 MB/s [ 143.8 IOPS]
Random Write 4KB (QD=32) : 0.509 MB/s [ 124.2 IOPS]
Date : 2014/01/10 19:20:07
    Dell Studio 1737
    Intel Dual Core
    2.10 Ghz
    400 gb
Uninstall what you have and download this. I know this is a pain for you, but the results will be worth it.
If this does not work better for you, just go with Miles, his advice is valid. I just thought that Crystal would be easier to use.
@MilesAhead
I got a little busy the past couple of days but last night I was able to DL the SeaTools for DOS program which required me to;
1) burn an image to a blank cd
2) go into BIOS and make the CD ROM drive the first to start up
3) then reboot the comp. with the cd rom (SeaTools DOS program) installed. As soon as it rebooted it started the SeaTools for DOS program right away.
4) then I ran a long diagnostic test which, after a good while, it found 50 errors with the hd
5) then it asked me if I wanted to repair the errors
6) after a few minutes, it made all the repairs and everything works great.
So I wanted to say THANK YOU Miles for the help. My comp is running fast again. All the lag and delays etc are gone. Thanks man.
Thanks to Richc46 for his help, you provided a lot of tips and things that have helped as well.
Thanks again guys,
Steve
    Dell Studio 1737
    Intel Dual Core
    2.10 Ghz
    400 gb
I have a Dell Studio 1737 laptop with Vista Home Premium Edition. It is running very slowly. When I try to open programs there is sometimes a long pause before they open. ....................
Thanks
I also have this problem on my Dell, 1 GB RAM, clean and efficient system. Unlike yours probably, my system slowdown occurs because of the dreaded System Volume Information (service?) that thrashes my hard drive insatiably. Once the System Vol. crud is done, the computer runs fine, fast, at least until the next time I do anything that adds files, plug in a flash drive, or most anything. Vista totally takes control and doesn't allow ME, the user, the privilege of performing MY tasks. It wants to do ITS thing first.
I despise Vista for this. I've asked, but have yet to find a way to STOP this Sys Vol Info junk from occurring. (BTW, I know it's Sys Vol Info doing this because the Resource Monitor tells me so). Would shutting down System Restore prevent this? Anyone?
Thanks.
EW
