Solved Not sure if this is the correct place to post.....
Fiery
Gday
I purchased a Samsung SSD 840 Pro, prior to installation I set the BIOS to AHCI. Put the SSD in and migrated my OS onto the new HD.
It wasn't until after a few boot ups, I noticed it was skipping the boot order of CD/DVD then HD. I double checked the BIOS to make sure this was indeed the correct boot order, it was.
I needed to boot off my Vista Disk, however, because it was skipping the boot order it didn't boot from the Disk.
The only way I could think of to get my boot order back, was to switch the BIOS back to IDE. Rebooted and it read the Disk.
What I would like, is to KEEP MY BOOT ORDER CD/DVD then HD.
Motherboard is a Gigabyte GA-MA770T-UD3P.
Any suggestions?
I contacted Gigabyte this was there response :-
Dear Susan,
Thank you for your kindly mail and inquiry. About the issue you mentioned, please change the battery and the model of the battery is CR2032. You can use any manufacturer for the bettery, but make sure the bettery model is CR2032 for 3V. After you change the battery, you may check if BIOS could work properly.
Regards,
GIGABYTE
N.B THE BIOS COULD WORK NOT WILL WORK!
    Homebuilt
    AMD Phenom II x 4 965
    4GB DDR3
    Nvidia GeForce GTX 750 TI
    Creative Sound Blaster X-Fi Xtreme Audio
    Phillips 19"
    1280 x 1024
    1 x 128GB Samsung 840 Pro SSD 1 x 1TB Sata 1 x 160GB IDE 1 x 2Tb WD External My Book Elite 1 x 1TB WD External My Book Elite 1 x 4TB WD External My Book
    Thermaltake 850W XT
    Coolermaster Storm Sniper Black Edition
    AC-ALPINE-64PRO ARTIC COOLING
    Microflacid Sterile
    12 year old Compaq, cant see any of the letters anymore :)
    ADSL2+
    My husband and I divorced over religious differences.. He thought he was God and I didn't.
Does the computer have a Fn key you can press at boot time to bring up a Boot menu where you can choose what device to boot?
On my Dell it's F11, on my Lenovo it's F2.
You can try resetting BIOS as follows:
1. Power down the computer and unplug the power cord.
2. Open the case and remove the CMOS (CR2032) battery.
3. Press and hold the power button for 10 cesonds or so.
4. Replace the CMOS battery.
5. Plug in the power cord and power up.
You should get a CMOS error, Press F1 to continue, F2 to enter Setup. Press F2.
See if there is an option of Fn key to load defaults. If yes, do it.
Set date and time then check Boot order/priority and set the way you want.
See if that helps.
    Windows 10 Pro X64
    Lenovo IdeaCenter K450
    Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz, 3401 Mhz, 4 Core(s)
    16GB
    NVIDIA GeForce GTX 750, Intel(R) HD Graphics 4600
    Samsung 27" C27F398 Curved Monitor
    1920 x 1080 (HDMI)
    Samsung SSD 840 EVO 250GB Seagate ST2000NM001 2TB Seagate ST31500341AS 1.5TB
    500W
    Lenovo USB
    50MB Down, 10MB Up
    Windows 7 Pro X64
    HP xw4400 Workstation
    Intel Pentium D Dual 3.4Ghz
    HP 0A68h
    5GB
    Realtek HD Audio
    Acer KN242HYL 24" (KVMS)
    1920X1080
    Seagate ST3120026As 120GB SATA (boot) Toshiba DT01ACA200 2TB SATA
    Logitech via KVMS switch
    Dell USB via KVMS switch
    50 Down, 10 Up
    Apache Web Server since 2001
See if that helps.
Yes I can boot from a disk if I use the F12 key. but I want to know why changing the BIOS from IDE to AHCI, has made the BIOS boot order redundant :mad:
    Homebuilt
    4GB DDR3
    Phillips 19"
    1280 x 1024
    Thermaltake 850W XT
    Microflacid Sterile
    ADSL2+
That I don't know, sorry.
    Windows 10 Pro X64
    16GB
    1920 x 1080 (HDMI)
    500W
    Lenovo USB
    50MB Down, 10MB Up
    Windows 7 Pro X64
    HP 0A68h
    5GB
    Realtek HD Audio
    1920X1080
    50 Down, 10 Up
I hate to say this but your firmware version may be too old for that hard drive. I try to avoid suggesting a BIOS update because if it goes wrong (update fails, wrong update selected, etc) then your motherboard could be permanently screwed up.
Although the battery option is worth trying and wouldn't cost that much to replace you'll have other issues though if the battery is dead such as the BIOS settings reverting to factory default settings and the time will keep getting changed. If you choose to change the battery do not touch it with your hands. Also make sure to take appropriate measure to prevent ESD. You can get a ton of how-to articles by googling that. Once I lost a floppy drive to ESD.
    Windows 8.1 Industry Pro x64
    HP Pavillion Elite HPE-250f
    8 gb
    ATI Radeon HD 5770 1 gb ram
    Alienware 25 AW2521HF
    1920x1080 &1680x1050
    1 TB x2
    Dell Poweredge T140
    8GB 2666MT/s DDR4 ECC UDIMM
    1 TB & 360 GB x2
Although the battery option is worth trying and wouldn't cost that much to replace you'll have other issues if the battery is dead such as the BIOS settings reverting to factory default settings and the time will keep getting changed. If you choose to change the battery do not touch it with your hands. Also make sure to take appropriate measure to prevent ESD. You can get a ton of how-to articles by googling that. Once I lost a floppy drive to ESD.
The BIOS has the latest update in it. I think I will just wait until my next rebuild, which while the boot order not being recognised, is more me being fussy about how I like things to work, as opposed to them not working at all.
    Homebuilt
    4GB DDR3
    Phillips 19"
    1280 x 1024
    Thermaltake 850W XT
    Microflacid Sterile
    ADSL2+
