Please Help!! Can't Type to log on, but unique problem
adamjbuda
Ok, SO I will explain the problem and how I got the problem and then yeah...
A few months ago, my HDD (ended up being just a wire tho) started to go so I bought a replacement cloned the drive to the new HDD and unplugged the old one. Everything has been awesome since then until 3 days ago.
3 Days Ago:
I installed Advanced System Optimizer and ran the one click scan. It scanned and found a bunch of errors that I was expecting as I have been erasing unneeded programs from the computer a lot since I switched HDDs. It also found a bunch of driver updates. I clicked to fix everything and it did, and drivers were installing. Then it told me everything was finished and my computer would restart in 60 Secs. about 30 secs into that countdown, a new driver install popped up (I believe it was intellipoint). It got about 90% (judging by progress bar) immediately, then just sat there. There was no "Cancel" button on the countdown, so the computer restarted. Everything restarted fine until it got to the log in page. When I get to the login page, I can use the mouse to point and click everything, but cannot enter a password with the keyboard. Before anyone asks, the keyboard is a ps/2 and the mouse is a USB wireless.
What I have done:
- used the BIOS. Can get to the BIOS screens and use arrows/enter. Can use f8 to get to advanced boot menu, reset everything do default, made sure USB was set right and tried ps/2 port on both enabled and automatic.
- unplugged and plugged in the ps/2 keyboard after it got to log in screen, tried a diff ps/2 keyboard (don't have a usb keyboard)
- ran diagnostic on startup and everything including HDD and Boot Path passed
- booted to safe mode no problem, but still can't type password to get in
-Spent at least 3-4 hours browsing forums and help pages on the subject with only finding "buy a new keyboard" or "system restore" as answer. Well, I don't have my windows boot CD, the comp is 6 years old and I have moved 3x since then. Can't find it.
Current Situation:
I have reinstalled the original HDD that I cloned back into the computer so that both drives are there. Made the computer boot off the old drive. Got to login page, and sure enough, the keyboard works. I can log in to that and no problem. However the old drive is SLOW, half the size, and after I cloned to the new drive I did major spring cleaning so that the computer was set up how I wanted, no malware, torjans, ads, hijackers, etc.
My questions:
- Is there a way to update the drivers on my new drive while booted on the old drive? (I have Microsoft Virtual PC installed, but no clue how to work it.
- Are there files from the old drive that I am currently booted from that I can copy to my new drive to fix the problem?
- Is there any way to bypass my login password on the new drive so I can boot it up and then update the driver from windows?
- Is there a way to force the computer to check drivers on startup?
I am really looking to try to figure this our without buying a new keyboard as I am currently typing with the keyboard that isn't supposed to work.
I am fairly competent with computers and I feel like I should be able to work around this with some help.
    NC686AA-ABA a6700Y
    AMD Phenom 9150 Quad-Core Processor, 1800 Mz, 4 Cores
    5 GB DDR2
What about trying a USB keyboard? If that works then you can try updating drivers.
    Windows 10 Pro X64
    Lenovo IdeaCenter K450
    Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz, 3401 Mhz, 4 Core(s)
    16GB
    NVIDIA GeForce GTX 750, Intel(R) HD Graphics 4600
    Samsung 27" C27F398 Curved Monitor
    1920 x 1080 (HDMI)
    Samsung SSD 840 EVO 250GB Seagate ST2000NM001 2TB Seagate ST31500341AS 1.5TB
    500W
    Lenovo USB
    50MB Down, 10MB Up
    Windows 7 Pro X64
    HP xw4400 Workstation
    Intel Pentium D Dual 3.4Ghz
    HP 0A68h
    5GB
    Realtek HD Audio
    Acer KN242HYL 24" (KVMS)
    1920X1080
    Seagate ST3120026As 120GB SATA (boot) Toshiba DT01ACA200 2TB SATA
    Logitech via KVMS switch
    Dell USB via KVMS switch
    50 Down, 10 Up
    Apache Web Server since 2001
If you are using numbers is numlock on? Have you tried safe mode?
    Windows 8.1 Industry Pro x64
    HP Pavillion Elite HPE-250f
    8 gb
    ATI Radeon HD 5770 1 gb ram
    Alienware 25 AW2521HF
    1920x1080 &1680x1050
    1 TB x2
    Dell Poweredge T140
    8GB 2666MT/s DDR4 ECC UDIMM
    1 TB & 360 GB x2
Try getting a copy of the driver while you have the old drive in and save it to a usb stick
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    Medium for New Zealand
How do i find out what drivers are the drivers I am missing? And I can't get into safe mode because safe mode you need to be able to log in, and I can't type my password there either.
    NC686AA-ABA a6700Y
    5 GB DDR2
    Windows 10 Pro X64
    16GB
    1920 x 1080 (HDMI)
    500W
    Lenovo USB
    50MB Down, 10MB Up
    Windows 7 Pro X64
    HP 0A68h
    5GB
    Realtek HD Audio
    1920X1080
    50 Down, 10 Up
