Solved Cooling motor speed on laptop
patch41
Vista Pro
Hi folks, my wife has a compaq presario f500 Laptop, 32-bit win 7, Could some one walk me through how to change the fan speed they have a problem with over heating, One of the suggestions is to raise the speed to high on all the time, I am not interested in conserving the battery as it is plugged in with an ac adapter 99% of the time, thanks
With laptops, it's very hit and miss to have the abiity to change fan settings.
I'd suggest you look into how to clean out the cooling fan and filter. Youtube has great how to videos.
I hate linking like this, but here is your laptops service manual
http://tim.id.au/laptops/hp/hp g6000 compaq presario f500.pdf
It's really worth looking into seeing if you are up to pulling it apart to clean it.
An alternative way is to blow aire into the exhaust as you use a vaccum to suck air from the in port.
Here;'s a good video
How to fix an overheating laptop : Clean your fans and heatsync with this procedure - YouTube
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
My experience with laptops is the fans die young. Most are a pita to change so I install new oem fans, not worth cleaning and hoping to get a few more years out of it. You can try blowing out the cooling area with a can of compressed air, it may help. It's a very good practice to blow out laptops every week or so, stops any accumulation that if it builds up is very hard to blow out.
    Dell Inspiron 1525
    T8300 2.4gzh
    dell
    Crestline
    onboard
    1200X800
Thanks for the reply's, I have taken the pc completely apart and cleaned out the cooling fan, But some of the suggestions on line was to change the speed of the cooling fan for added assurance, I have been in the bios but I could not see an option to change the speed, Thanks Patonb for the link you gave, for the manual for f500 Presario, I put that in my favorites, also on line I found a nice freeware program which monitors more closely the fan speed, I installed it and hopefully it will monitor more closely, thanks again.
SpeedFan - Access temperature sensor in your computer
Speedfan is a very comprehensive program, and it may be possible to change your fan speed with it, hence why I said it's touch and go with laptops.
I usually use coretemp to keep my temps monitored.
