Solved Vista Home Premium 32BIT - Problem
Waldze
Hello!
My parents laptop are not working, and I have now been trying to fix it for 2 days. But cant find out how to do it.
Its a DELL STUDIO 1555 with Vista Home Premium 32BIT The problem is that the laptop dont start normally, First it just went black after the Window´s loading bar is done. Now I tryed to use the Vista Reinstallation DVD and comes to this menu with languages and the System Recovery Option´s. But when I shall choose a operating system to repair there is none there and It says I have to load drivers and find the driver. But I have no idea where to find it or what the name is of it.
Anyone know how I shall do this?
Or got any idea what the problem is?
Please just ask me if theres something more you guys want to know.
Thanks in advance!
Welcome
Test to see if it works in safe mode. If it does we can fix it for you.
Thanks for the quick answer and the welcome!
I did try it and a blue screen with a white text popped up for a second and then the computer restarted agian.
The text says following:
"A problem has been detected and windows has been shut down to prevent damage to your computer.
UNMOUNTABLE_BOOT_VOLUME
If you create a recovery DVD, you may be able to boot to recovery options
Create Recovery DVD.
Hard Disc Controller must be set to IDE in BIOS and Bios must be set to boot from the CD Boot Priority - Change
The Vista recovery disk is used to boot Vista when it won't boot - to run Startup Repair, System Restore, access a Command Line, Recover using a Vista Backup Image, etc.
System Recovery Options. Choose an option tht will not cause you to lose your stuff.
If Vista will not start now, boot the Recovery CD to run Startup Repair which automates System Restore as well as numerous other tests including System File Checker which can repair system files which are not corrupted beyond repair.
If Vista still will not start, try booting into Safe Mode to run sfc /scannow to repair System files.
Special Thanks Given to Seven Forums.
Below is a bulletin distributed by MS to explain the start up procedure when Windows will not boot.
  • Startup Repair. Startup Repair is a Windows recovery tool that can fix certain problems, such as missing or damaged system files, that might prevent Windows from starting. Startup Repair is located on the System Recovery Options menu, which is on the Windows Vista installation disc. If your computer has preinstalled recovery options, it might also be stored on your computer's hard disk. For more information, see Startup Repair: frequently asked questions and What are the system recovery options in Windows Vista? If your computer does not include Startup Repair, your computer manufacturer might have customized or replaced the tool. Check the information that came with your computer or go to the manufacturer's website.
  • Change restart settings in safe mode. If your computer is stuck in a loop where Windows fails, attempts to restart, and then fails again repeatedly, restart your computer in safe mode and select the Disable automatic restart on system failure checkbox. For more information, see Advanced startup options (including safe mode).
  • Reinstall. If no other options have solved the problem, and you are sure that your computer's hardware is functioning normally, you might need to reinstall Windows. A custom (clean) installation of Windows will permanently delete all of the files on your computer and reinstall Windows, so only use this option if all other recovery options have been unsuccessful. After the installation, you will need to reinstall your programs and restore your files from backup copies. For more information, see Installing and reinstalling Windows**.
Try system restore, if that does not work, we may have to back up your stuff and then move on.
I tried it and it says following:
"To perform an offline System Restore, you must specify which Windows installation you would like to restore.
For example, if the installation located in "C:Windows" should be restored, enter the following command:
Rstrul.exe /OFFLINE:C\Windows
Sitting at my summerplace so Iam without internet on the laptop ..
Thanks agian!
Do you have any stuff that you want to save before we proceed?
We will start the easy way first.
Make and model of computer, please.
Sorry, you did tell me that. I will try to get info that can help If it does not help there are still other solutions.
I did not find Dell Factory Image Restore. Im at System Recovery Options, maybe Im at the wrong place? There is something called Dell Datasafe Restore and Emergency Backup, i tryed to click it but seems like nothing happens ; o
Want me to take a screen of it?
Did you carefully follow the instrutions shown in step 3?
Check your computer carefully. Somewhere on the case or inside the battery slot, there will be a product key number.
25 digits and/or letters. Every 5 are separated by a dash. If you find that number you can use this to reinstall your Vista.
Windows Vista Direct Download Links=
How shall I be able to download that stuff, since I cant go on the web? I got the reinstallation CD, and comes to a screen that says Install now.
