Solved default boot problem .big problem
yvesj
hi .i made a really big mistake .
i did go in the bios and i change the boot to default .
now my computer will not open at all .
i did go back in the bios but i cant not fine were to put it the way it was before .or to undo the change
do you know to change it back to normal .
i am using vista
    build by me last summer
    cpu.3.00.ghz
    asrock fm2 -75 pro
    g-skill 1333 7-7-7-21 4 gbs
    none
    none
    22 ecer x223w
    crusial m4 128 gbs
    apevia.atx-as500 blue led
    thermatake armor a 30
    5= 80 mm led fans
    logitech
    logitech mk 300
thank .
i did try that ans it did not work .
but it is ok i just order a new sdd drive again .
i will reinstall vista when i get it .
my problem was i reinstall vista and i did land up having 2 vista on top each other.
like when i was booting i was getting 2 screen logo one after the other one and you could see it loading a lot of stuff .it took maybe 7 secs only for the microsoft bar to show up .
not only that my boot time was close to double that i was .
then after my fisrt install i had 84 gbs left and after i reinstall vista all i had is 63 gbs left
    cpu.3.00.ghz
    asrock fm2 -75 pro
    none
    none
    22 ecer x223w
    crusial m4 128 gbs
    5= 80 mm led fans
    logitech
    logitech mk 300
good new this morning.
i turn it on guess what the dem thing came on like nothing happen .
yesterday after i default the dem thing i did have nothing .
so why this morning it is back on normal .
that mobo is getting to scare me like hell ..
my boot time this morning is 40 secs .
go figure .
now i know why i have 2 vista to boot in to .
when i did reinstall it i did not create a partition .
now i know but it to late .
    cpu.3.00.ghz
    asrock fm2 -75 pro
    none
    none
    22 ecer x223w
    crusial m4 128 gbs
    5= 80 mm led fans
    logitech
    logitech mk 300
Glad that you got it sorted.
Ill mark this as solved.
thank you .
you do that for me
    cpu.3.00.ghz
    asrock fm2 -75 pro
    none
    none
    22 ecer x223w
    crusial m4 128 gbs
    5= 80 mm led fans
    logitech
    logitech mk 300
