I was just taking apart my desktop and cleaning it up/blowing off the dust using a pressurized air gun (not too pressurized), and now that I have the nuts and screws back on, I plugged it in and the loudest noise began to come from the cooling fan.
It sounds as if theres something hitting the fan as it turns, this only happens on start-up for about 5 seconds as the fan blows at full speed. I did a visual inspection and there was nothing close to the fan, all wires were tucked away. What should I do?
- HP Pavilion G6
- 750GB HDD 6GB RAM
- AMD A6-3400M APU with Radeon HD Graphics
- 25mbps
