Device Management Shrink Volume is not working on C drive
chaitu87
My C drive has lot space, nearly 170 GB free space. I do want to shrink C drive, and allocate that memory to another drive to keep files. To do so I am using shrink volume option in device management window. When I clicked on Shrink volume it showing 0 MB is allowed to shrink, even though it has lot of memory unused. Please help.
    Emachine ET 1161-05
    AMD Athlon 64 LE-1640
    1280x768 pixels
    ST316081 5AS SCSI Disk Device
    Tower
    Fan Speed 1247 RPM
    PS/2 Compatible Mouse
Excellent Yard Dog. I did a bunch of searching in the windows help file trying to find a possible solution and ended up with nothing. I hope this works.
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
Tell ya what, that Tutorial section is a master file of fixes..
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
Being relatively new the forum, I didn't even think of the Tutorials. Thanks.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
You will not be able to shrink C:\ with Disk Management because the MFT (master file table) is sitting high up in the partition and Disk Management cannot move it.
What you need is the bootable CD of Partition Wizard (last entry on the webpage). Burn this .iso to CD and load it from the CD reader (change the BIOS boot sequence). That program can move the MFT and you can shrink as much as there is free space. I would, however, not make C:\ too small - maybe 60 to 80GB.
Btw. You do not "allocate memory to another drive". You allocate disk space to another partition. Memory is RAM and a drive is a physical disk.
    Dell
    Q6600
    HP w2207h
Your most welcome. We all do our best to assist on issues.
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
