System will not power on without system restore/scannow stuck at 51%
lacontessa
I will try to put all the relevant information here, but this is the first time I have ever posted at a computer help forum. Please let me know if you need more information.
1. Within the last week, my laptop (Toshiba Satellite L505D) has started not turning on. I turn it off every night, and starting this week, suddenly I got nothing but a black screen when I turned it on in the morning. I hit the power button and turned it on and off several times (hitting "Start Windows Normally"), to no effect. I then tried the "System Repair" option (I don't remember if that is the correct wording, but it is the option that isn't "Start Windows Normally"). It takes me to the "System Restore" dialogue boxes, and after a lot of sitting around and several re-starts, the computer eventually brings me to the desktop. This has happened every day this week--the System Restore option works one time only. Once the desktop has loaded, there are no real problems, except . . .
2. Today I decided to fix this powering on problem, because it's annoying and sometimes I need to get into my computer quickly, so I did an online search. One of the recommendations was to use sfc/scannow to repair corrupted system files. I tried it three times (using "Run as Administrator"), and each time the verification stopped at 51% with the error message, "Windows Resource Protection could not perform the requested operation."
I have used CCleaner twice this week to clean up my system and my registry, with no effect on the above problems.
I'm not sure what additional information you need, but I am running Vista Home Premium 32bit. I have attached the sfcdetails.txt file. Please let me know if you need anything else.
Thank you for your help.
    Emachine ET 1161-05
    AMD Athlon 64 LE-1640
    1280x768 pixels
    ST316081 5AS SCSI Disk Device
    Tower
    Fan Speed 1247 RPM
    PS/2 Compatible Mouse
The reason for backing up now is that IF the hard drive is failing, you will lose all your important stuff. Holler when you are ready to test out the hardware, as we have a couple of tests to run .
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
Well . . . I don't think I'm going to be able to do this after all. I got busy at work, so it took me a while to make progress on backing things up. In the meantime, I dropped my computer, and now it won't read any new, un-formatted DVDs (it will read DVDs that have already been formatted, but I can't get it to read new DVDs so I can format them and put more files on them). I learned a lesson, though: don't throw away the old back-up DVDs until the new ones are completely finished.
At any rate, I am going to have to take the computer to Best Buy for the DVD drive anyway, so they may as well check out the other issue as well (and maybe they can back everything up for me). Thanks for your willingness to help, though!!
Well, we wish you good luck and say to you to come back any time . We are always here for you.
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
