Mouse lag - need help - very irritating!!!
Hello and welcome to the Forums, have you tried another mouse ? How about Device manager, update driver for it ? Post back if you tried that and it still lags please.
    Emachine ET 1161-05
    AMD Athlon 64 LE-1640
    1280x768 pixels
    ST316081 5AS SCSI Disk Device
    Tower
    Fan Speed 1247 RPM
    PS/2 Compatible Mouse
Go to search, type devices and printers. Upadate the mouse driver.
Try mouse on another computer to locate the cause.
Try devices and printers.
Did you try another mouse ?
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
Did you try that mouse on another computer?
    Windows 7 Pro & 10 Pro
    HP Pavillion Elite HPE-250f
    8 gb
    ATI Radeon HD 5770 1 gb ram
    Alienware 25 AW2521HF
    1920x1080 &1680x1050
    1 TB & 500 GB
I changed the mouse to a laptop and it appears to work fine. I have another older usb optical mouse that works well. I also in a different usb port. Is it possible the port may have "gone bad?"
Well, you tried same mouse on another computer, you tried another port using another mouse, So, if the original mouse works in another port ,but, not the original port, then yeah, must have become bad/faulty somehow, you said you verified drivers. Maybe somehow the connection came loose, a repair shop can check it for you. But , as long as the other usb ports are working, then not much else you can do.
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
