Graphics Issues after running ComboFix
cja1987
Hello All,
Hoping somebody might be able to help me.
I ran combofix to get rid of the google redirect virus and it worked great for that. However, I'm having issues displaying graphics in multiple programs. For example, when I try to open a photo in windows photo gallery, I see the outline of the window and can click on all the buttons. I also see the thumbnail of the image off in the margin. However, where the large version of the photo would pop up, I just see the desktop behind the window. The desktop "freezes" into the view window and will move as you move the windows gallery window around with the mouse.
The same thing happens with google earth, I can see and interact with the entire interface (file menu, etc) but I just see the desktop where I'd normally see the map.
This is the case for many other programs too. FLV player will play audio but you don't see the video. A program I have for radar analysis will work but not display the radar imagery.
In every case, you just see whatever is behind the active window where you should be seeing some type of graphics.
I've tried reinstalling some of these programs with no luck. This leads me to believe the ComboFix deleted something important (registry entry(s) drivers, etc).
Can anybody think of anything obvious that would cause this behavior? I can post the ComboFix log if it would help anybody.
Thanks for reading!!!
If you are sure your PC is now clean, try re-installing the graphics drivers & the installed codec's for your PC.
I will need the make & exact model number, then we will be able to assist you further. OK?
    HP-Pavilion m9280.uk-a
    ASUS NVIDIA Geforce GTS450
    HP w2408 24.0" (Dual monitor)
    1920 * 1200, 1920 * 1200
    40 Meg
    Emachine ET 1161-05
    AMD Athlon 64 LE-1640
    1280x768 pixels
    ST316081 5AS SCSI Disk Device
    Tower
    Fan Speed 1247 RPM
    PS/2 Compatible Mouse
Thanks so much for being willing to help!!!
Make: HP
Model # x16t-1200
Informal model is "HDX-16t"
Let me know if you need any more info.
Thanks again!!!
    40 Meg
Look here for the latest Nvidia drivers for that machine (You will need to install the auto scan software): -
NVIDIA Driver Downloads - Automatically Detect NVIDIA Products
Other drivers available here: -
Software & Driver Downloads HP HDX X16T-1200 CTO Premium Notebook PC - HP Customer Care (United States - English)
Thanks for your help, this is great to have!
Unfortunately, neither the Nvidia update nor the updates suggested by HP helped my problem. I think this going to be a real pain to chase. Almost leaning towards reinstalling windows as much as this pains me.
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
I am lilbit96 you see looking at that Thread.. LOL... Stick with Bleeping Computer at this pt. and let them fix you up. Not good to have 2 help forums working one issue.. Good luck .
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
