I have an Acer Aspire M5711, intel core2 quad, Vista Home Premium 64bit(OEM), it's 2.5years old and have never done any re-installation.
Some history (tried to be brief... sorry..):
Few days ago my comp just restarted itself and boots into repair/recovery mode, but i think the system overheated and the comp just shuts down again. So i cleaned my fan and booted again. but it refuses to boot(ran the bar for ~5mins) and gave 2 options: repair mode and start windows normally. tried both options and went back to the same screen. Pressed F8, tried last known good configuration(ran the bar and restarts again) and safe mode stops at crcdisk.sys.
Thought i would just back up my data and reinstall Vista or use system restore. So, I used Ubuntu LiveCD and backed up my D drive but i cannot access C drive(ubuntu told me to run chkdsk /f in windows). Googled and the solution given is to run Vista installation disk and use the 'repair your computer'. So now i'm stucked at 'System Recovery Options', it doesn't locate any vista OS and tried 'load driver'. Downloaded driver from acer website, but now i'm not sure if i downloaded the correct driver.
(Download)
so i used the chipset driver, in the folder IDE>WinVista64>sataraid>nvrd64.inf
but a pop up says: 'The specified location does not contain information about your hardware.'. Search all other folders and could not find any raid controller driver.
Questions:
1. Am i on the right track? i really need to recover the data on my c drive, good deal of my uni work are there..
2. Where can i find the correct driver if that is what i need?
3. Else, what are the steps i should take?
Thanks so much for your help=)
Cheers!
Questions:
Cheers!
- Acer Aspire M5711
- Intel Core2 Quad
- WDC 640GB
So all I can offer is an alternate backup method if no one else comes along with ideas to fix it.
