I think it all happened after I unchecked IPv6 from Internet Protocol, which I cannot access now to recheck since my "connection status is unknown/class not registered", windows installer doesn't work, system became slow while using windows explorer, no sound, etc.
Curiously I have internet access.
Below are the error details.
If I have to register some dll with regedit please let know step by step, I'm not a PC genius at all.
I much appreciate your input.
Code:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.Runtime.InteropServices.COMException (0x80040154): Class not registered (Exception from HRESULT: 0x80040154
(REGDB_E_CLASSNOTREG))
at System.Management.ThreadDispatch.Start()
at System.Management.ManagementScope.Initialize()
at System.Management.ManagementObject.Initialize(Boolean getObject)
at System.Management.ManagementClass.GetInstances(EnumerationOptions options)
at System.Management.ManagementClass.GetInstances()
at ProcessManager.GetAllProcesses.GetAllProcess(TreeList TreeListName, ImageList ImageListName)
at ProcessManager.frmMain.GetProcesses()
at ProcessManager.frmMain.frmMain_Load(Object sender, EventArgs e)
at System.EventHandler.Invoke(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ContainerControl.WndProc(Message& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.4214 (VistaSP2GDR.050727-4200)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
ProcessManager
Assembly Version: 1.5.0.0
Win32 Version: 1.5.0.0
CodeBase: file:///C:/Program%20Files/Yamicsoft/Vista%20Manager/ProcessManager.exe
Microsoft.VisualBasic
Assembly Version: 8.0.0.0
Win32 Version: 8.0.50727.4016 (NetFxQFE.050727-4000)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.
VisualBasic.dll
System
Win32 Version: 2.0.50727.4215 (VistaSP2GDR.050727-4200)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.
Forms.dll
System.Drawing
Win32 Version: 2.0.50727.4016 (NetFxQFE.050727-4000)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Runtime.Remoting
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.
Remoting.dll
DevComponents.DotNetBar
Assembly Version: 5.0.0.0
Win32 Version: 5.0.0.0
CodeBase: file:///C:/Program%20Files/Yamicsoft/Vista%20Manager/DevComponents.DotNetBar.DLL
DevExpress.XtraTreeList3
Assembly Version: 1.11.1.0
Win32 Version: 1.11.1.0
CodeBase: file:///C:/Program%20Files/Yamicsoft/Vista%20Manager/DevExpress.XtraTreeList3.DLL
DevExpress.XtraEditors3
Assembly Version: 3.2.1.0
Win32 Version: 3.2.1.0
CodeBase: file:///C:/Program%20Files/Yamicsoft/Vista%20Manager/DevExpress.XtraEditors3.DLL
DevExpress.Utils3
CodeBase: file:///C:/Program%20Files/Yamicsoft/Vista%20Manager/DevExpress.Utils3.DLL
Tracker
Assembly Version: 1.0.844.28400
Win32 Version: 1.0.844.28400
CodeBase: file:///C:/Program%20Files/Yamicsoft/Vista%20Manager/Tracker.DLL
System.Xml
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Data
CodeBase: file:///C:/Windows/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
Accessibility
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
VMPCL
Assembly Version: 1.1.7.0
Win32 Version: 1.1.7.0
CodeBase: file:///C:/Program%20Files/Yamicsoft/Vista%20Manager/VMPCL.DLL
System.Design
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Design/2.0.0.0__b03f5f7f11d50a3a/System.Design.dll
System.Management
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Management/2.0.0.0__b03f5f7f11d50a3a/System.Management.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
- Gateway GM5664
