Major Advent QT5500 Problem Needs Recovering
Hello there vista forum users
I have recently wanted to reinstall vista 32bit to my laptop due to viruses and freeing up space. whilst i was reinstalling using a recovery disc i got the error code 4 could not copy something to partition(maybe recovery partition) since then i downloaded files for a new recovery disc i tried startup repair but my laptop says 0 windows installations so it cannot even find my os vista.
i looked at the results and i get the error Boot Manager is missing or corrupt, i have tried many commands such as rebuild bcd and fixmbr they both say succesfully completed but neither work.
At startup recovery it doesnt find an OS but it says i can load drivers which says the installation has failed. I've read around the internet some people say it could be a harddrive failure but i doubt it because it was working fine and also on the results error it said hard drive was fine.
On startup i get the message bootmgr could not be found press (cntr alt del) to restart.
I believe my pc is in a very bad state with no OS and my C: drive is empty, please could i have any response as im stuck trying to figure out what to do i will give more info if needed
Help will be much appreciated thanks Luke,
    Advent QT5500
One possibility is that your OS partition is not set to "Active". In that case the MBR would not find the bootmgr and everything falls apart.
You can check that with the bootable CD of Partition Wizard (last entry on that webpage). Burn that CD and load from the CD. If it is not active, you can set it active with the same program. The controls are under the Partition tab > Modify (you have to first highlight the partition).
    Dell
    Q6600
    HP w2207h
Ive burnt the iso to disc but when I put disc in it doesn't say press any key to boot it just says bootmgr missing press ctrl alt del to restart
    Advent QT5500
right its set as active now what do i do and thanks for the help so far
    Advent QT5500
