Tonight I decided to do a system recovery(re format of my computer).
I have a Gateway desktop DX4820-07h with a pre-installed vista on it.
It comes with a 3 System Recovery Discs which I then used to perform the reformatting of the whole C: drive. After successfully installing, however, it prompts me to restart the computer and get stuck in the *
*********** The computer restarted unexpectedly or encountered an unexpected
*********** Error. Windows Installation cannot proceed,. To install Window, click
*********** “OK” to restart the computer, and then restart the installation.
loop.
I have tried doing the system recovery more than 3 times with no luck and I cant either access safe mode.
I also saw in some forums to change the ddr voltage thing but theres no way in my computer BIOS to access it. Some people suggest to try taking out one ram. is this worth a try?
I actually partitioned the hardrive of this computer 400gb for D: and 600gb for C: which is not the default settings when i first bought it (only C
does this affect the problem?
I appreciate your help.
loop.
