Side by Side Config and Net Framework problems
guy9
Hi all,
After a sudden computer freeze (during normal net browsing) I have problems with side by side configuration and also Net framework.
The computer starts normally but I get the message from GoogleEUlallauncher:
"impossible to load c:\windows\microsoft.Net\Framework\V2.0.50727\mscorwks.dll"
Then I can not start several applications. they give the message:
"application has failed to start because side by side configuration is incorrect"
Among those applications are: Acrobat reader, AVG (virus), Google earth, Msworks,FSX(flightsim)
The application ADE (Airport Design editor, FSX) gives on start the same message as GoogleEUlallauncher concerning FrameworK.
I have made some research already on your site and found some threads about this side by side
Problem as this one for example:
http://www.vistax64.com/general-discussion/283887-side-side-configuration.html
So I have already tried to do what is said there.
I have reinstalled (repair) the Microsoft Visual C++ libraries.
I have also tried to reinstall Microsoft.Net frameworK
For Net Framework 2.0 to I got the message that is was part of the system and that it could not be installed. (I use Vista 32 bits)
For Net Framework 3.5 Sp1 I got at the end an error message with code "1603".
I have also done already SFC and SXSTRACE.
You have the logs attached.
For Sxstrace I launched Acrobat,Avg, Google Earth and ADE , in that order.
Would be happy to know if there is a possibility to avoid a reinstall!:D
I use Vista 32 bits (french edition).
You find my other computer specs in my profile.
Guy
    Medion P7300 D
    Core 2 Quad E8200
    MSI Intel-P35
    4 GByte RAM
    MSI Geforce-9600GT
    ACER LCD
    Western-Digita
If I understand well Sxstrace and Sfc signal the manifest
x86_policy.8.0.microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4053_none_516e2e610f48bda6.manifest
as the origin of my problems.
Something seems wrong with the "Noinheritable" in line 3!
Those internet addresses at the end seem also bizarre!
What can be done about that?
I have attached the manifest.
Guy
    Medion P7300 D
    Core 2 Quad E8200
    MSI Intel-P35
    4 GByte RAM
    MSI Geforce-9600GT
    ACER LCD
    Western-Digita
I have run also now the System Update Readiness Tool for vista, that you indicated in the other thread.
It signals again the same manifest and could not repair.
The Checksur.log is attached.
Guy
    Medion P7300 D
    Core 2 Quad E8200
    MSI Intel-P35
    4 GByte RAM
    MSI Geforce-9600GT
    ACER LCD
    Western-Digita
Hello guy9 and welcome to the forums :party:
Do you have a Vista installation DVD?
Tom
    Build #1
    Intel Core i7 3770K @4.4GHz
    ASUS P8Z77-V PRO
    Integrated on motherboard
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
Hi Tom,
Thanks for your answer.
I have the Vista installation Dvd.
It should be possible to recuperate that failing manifest from there!
Guy
    Medion P7300 D
    Core 2 Quad E8200
    MSI Intel-P35
    4 GByte RAM
    MSI Geforce-9600GT
    ACER LCD
    Western-Digita
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
Thanks for your answer, Tom.
Is there really no other and simpler possibility to recover that ONE file?
I would prefer to retain the Repair Install as a last possibilty, because I am afraid it could lead to other problems (loss of data etc).
Guy
    Medion P7300 D
    Core 2 Quad E8200
    MSI Intel-P35
    4 GByte RAM
    MSI Geforce-9600GT
    ACER LCD
    Western-Digita
Welcome
Repair install should not create problems, I suggest that is the way to go. Other alternatives include fixing the Side by Side if another memember knows the procedure or reinstall. There are always riskes involved, but you may want to reduce the chance of problems by downloading Ubuntu and trying to save your stuff. Good luck
I did some research on the net and found a source for the corrupt manifest in another forum where someboby had similar problems.
This manifest seems to be part of Visual C++ 2005.
So I took the ownership of the manifest file and replaced it by this new version.
(one can use notepad to modify a manifest!)
Now everything works again normally! :D
The manifest is
in c:\windows\winsxs\manifests
Attached is the version I used for replacement.
Guy
    Medion P7300 D
    Core 2 Quad E8200
    MSI Intel-P35
    4 GByte RAM
    MSI Geforce-9600GT
    ACER LCD
    Western-Digita
